Question about OKI C5500n Printer
Close cover 310: cover open, but it isn't
Close cover 310: cover open and
close cover 311: cover open
Covers are not open
  • 186 Answers
SOURCE: 310, 311 318 paperjam can not find it
is the paper in the fuser, try turning the fuser, sometime there are some small pieces of paper stuck in between the fuser and pressure roller
Posted on Feb 19, 2010
SOURCE: Brother DCP 7020 error 'back cover open close
Thank you Daniel - it worked for me!
I just spoke with a Brother Customer Service Rep. and he did not mention this potential fix. He ended up recommending a local service center, but suggested that it might be less expensive to purchase a new pinter instead.
Note to others: the tiny perpendicular appendage is on the (this thin black plastic)flap that you pull down to expose the orange roller. There was a separate black piece on the flap that was slightly bent & "jossled out of the slot" as Daniel mentions.
I hope this works for you as Daniel's advice above just saved me about $170 on a new printer - Thank you!
Posted on Apr 28, 2010
SOURCE: close cover 310: cover open, but it isn't
had the same problem. It is easily fixed.
On my printer a OKI C5750 is had to main covers, at the front (which you have to open to fix a paper jam) and a big cover on top (which you need to open to replace toners).
On the left is a piece of plastic which (when closed) presses on a switch.
When you open both covers, and close the top one, you can see it on the left when it comes down.
You can easily remove the error (only for a brief moment) by prushing the shining metal switch to the back.
But the problem is that one of the rollers is in a wrong position.
So just take a flat screwdriver and press on the bottom roller, and it will click and the problem will be gone when you close the covers.
Posted on May 07, 2010
Take a look at this and see if this is why:
Open the front door, as when you have a paper jam.
On the left is about a 3" curved white plastic swing hing guide piece, slotted in the middle.
On the metal wall to the left of it is a tab bent out to fit into this groove. If the Tab is not fully in the groove, it will prevent the front door from "fully" closing on this side, preventing it from actuating the switch mentioned by others.
A simple fix that solved it for my OKI C5650 "310/311:Cover Open"
Posted on Jun 20, 2010
rickbrashear
  • 176 Answers
SOURCE: Message on my window: Error -
https://www.canon-europe.com/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MX_series/PIXMA_MX870.aspx?faqtcmuri=tcm:13-716137&page=1&type=faq
here is a website that tells how to correct jams and also shows some pictures of all the door openings, It sounds like the cover that holds you bulk paper, sometimes there is a lid on top of it. it may not be seated properly.
hope this helps
Posted on Jan 28, 2011
Formate nokia310
Please always Remember, while doing Master Reset Nokia Asha 311 to factory default, the data will be loose, that's why we can do backup all data or important stuff at Nokia Asha 311.
#Option 1, Hard Reset Nokia Asha 310 & 311 with menu setting:
  1. Make sure the Nokia Asha 311 on and standby
  2. Go to menu Setting, then choose restore factory setting > settings only
  3. It will ask security code, input default security code of Nokia Asha 311 : 12345
#Option 2, Hard Reset Nokia Asha 310 & 311 with special code / master key / shortcut / secret key :
  1. Try to type: *#7370# and it will ask the security code of Nokia Asha 311, press 12345
  2. You also can try type: *#7380#
#Option 3, Soft Reset Nokia Asha 310 & 311 with special key code :
Please take attention, this option is for soft reset, so Nokia Asha 311 will not removing any important data and installed applications. How soft reset Nokia Asha 311 work: It will recopy or restore the default copy of .ini to Nokia Asha 311.
  1. Type in the phone : *#7780#
Jul 31, 2013 | Electronics - Others
Back cover open message although cover is closed
Open the top and back covers. If you see any jammed paper or
other item, gently pull it out, then close the covers. If the error message
remains, open and close the covers again. If the FAX/MFC cannot reset
itself and return to the date and time prompt, it will display MACHINE
ERROR XX. Please call Brother Customer Service
and tell them the Machine Error number at:
In USA:
1-800-284-4329
In Canada:
1-800-853-6660
In Montreal:
1-514-685-6464
Jan 15, 2011 | Brother IntelliFax-2820 Laser Fax
Front and rear cover open but all covers are closed
hello check again properly.i think front cover is open
if you replace toner and didnt close front cover properly or you open it and didnt close properly.
Sep 09, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Just bought MX870 and put power on and it says "The feeder cover is ope Close cover and press ok." I closed every cover and pressed ok but still shows that error.
The two covers on top are just not aligned properly. Open both top covers (one opens to the right one to the left). Close the cover that opens toward the right 1st (you should hear it click into place) then close the second cover. Press "ok" should be good to go.
Sep 01, 2010 | Office Equipment & Supplies
I am having problems with my 1988 Chrysler New Yorker motorized headlight covers. Both headlight covers don't close completely when I shut the headlights off. There is about 3 inches to go on both...
I have the same problem with my 93 Salon. Take a look at the torsion bar rod end close to each headlight.There are collars that have a set screw which can be loosened to adjust the range of the door opening and closing. If the doors are going through the full cycle open to close but fall back and leave a gap such as you describe, most likely you will only need to adjust those screws. Each door will require adjustment individually. May require an allen wrench. Hope this helps.
Aug 11, 2010 | 1988 Chrysler New Yorker
OKI error 310 and 311....
both are "cover open errors"
310 is top cover
311 is front cover
make sure both are closing properly.
Jun 18, 2010 | OKI C3400n Laser Printer
Dear Sir(s) I have an OKI data OL400e the problem is "Message --Cover open" even i close it well Please advice Thanks
Feb 11, 2010 | OKI OL 400e Led Printer
Nov 23, 2009 | OKI C3400n Laser Printer
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
My Brother 560 says top cover open when the cover appears closed.
Make sure the covers are completely closed. Open each section an close it making sure it closes with a click. Also check for covers under other covers.
Hope this is of some help.
ED
May 09, 2009 | Brother IntelliFAX 560 Plain Paper Fax
OKI C5500n Printer Logo
503 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
