Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Front suspension on a 1968 sportster
I need to remove the bushings in my front shockabsorbers on a 1968 harleydavidson sportster
Man its been awhile since i saw one of those. i wish hd still made rebuildable front ends instead of throw away *** units. run your finger to the bottom of bushing to see if there is a lip on the bottom, if so, go to harbor freight and buy a blind bearing removal set if it will go to the size you need. if not, they also sell a slide hammer tool with claws that will work if it will go into the hole. if all else fails, take a hack saw blade and carefully cut the bushing almost through on opposing sides, try not to scar tube. you can then use a small screw driver and work the bushing out at one of the slits, once the tension is gone, it will pick out. other than that, find an old hd shop. as an after thought, there are expanding pipe ez outs which should clamp to the bushing allowing you to pull it out but do not over expand so damage to the tube will not occur.
Posted on Sep 07, 2008
How to replace front bushes For 2006 ford territory
remove the suspension arms and press in the new bushes
however check around auto spares shops as it may be cheaper to get new suspension arms complete with bushes cheaper that bushes and labor to replace them
example suzuki lower arms bushes per arm $120.00 = 1 1/2 hours time @ $120.00 / hr compared to new arms $130.00 each
it doesn't cost to ask first
May 06, 2017 | Ford Cars & Trucks
Looking for replacement shock for seat bar lift.
Amazon.com: HomCom 3.2" Universal Replacement ...
www.amazon.com/...Replacement.../B008XVEZG8
Amazon.com, Inc.
Rating: 4.2 - ‎123 reviews
Office Chair Pneumatic Gas Lift Cylinder Piston Replacement - Universal Size ... much right on the money and I have to say that the price just simply cannot be beat when you start looking for pneumatic gas lifts! ... ·With PP gas bar cover ....Replacement Office Chair Gas Lift Cylinder Pneumatic Shock - 5" Travel - S6111.
Lift Kits -Body Suspension Lift Kits, Bump Stops & Sway Bar ...
www.4wheelparts.com > Suspension
Lift Kits -Body Suspension Lift Kits, Bump Stops & Sway Bar Bushings ... ShockAbsorber Bushing. Upgrade or replace your ... Shock Link Kit. Shock Link Kit. Lift ...
Complete Suspension Systems and Lift Kits - 4 Wheel Parts
Dec 27, 2015 | Toys
I have pulsar 150cc 2004 model now the time its handling front or rear is to bad what should i do
Check the rear swinging arm bushes and also check the shockabsorbers bushes too.
Oct 28, 2010 | 2005 Bajaj Pulsar 150
Need to know how to replace lower control arm
LOWER CONTROL ARM
REMOVAL
1) Raise and support vehicle. 3) Remove the steering knuckle.
Remove the bolts fastening the power steering cooler to the front suspension cradle crossmember reinforcement (Fig. 21). 5) Remove the lower control arm rear bushing retainer bolts located on each side of each lower control arm rear bushing. NOTE: The bolts fastening the cradle crossmember reinforcement are of three different thread sizes. Note the location of the various sizes.
6) Remove the bolts attaching the cradle crossmember reinforcement to the front suspension cradle crossmember (Fig. 22). Remove the 2 bolts fastening the reinforcement and rear of cradle crossmember to the body of the vehicle. Remove the reinforcement. 7) Remove the pivot bolt attaching the front bushing of the lower control arm to the front suspension cradle crossmember. 8) Remove the lower control arm.
Sep 25, 2009 | 2006 Dodge Caravan
My front suspension will not go up only the rear is up and the front stays down.
The only reason i can see hanging to your problem is either your shockabsorbers or spring coils. Let them check by a professional.
Sep 07, 2009 | 2003 Lincoln Navigator
How to remove front stabilizer bar in '05 Scion TC
I don't know if you can get the bushings out without changing the bar or not, but changing the bar is a big job for a DIY. I was thinking about it but will probably have a pro do it for me. From the shop manual: 1. PLACE FRONT WHEEL FACING STRAIGHT AHEAD 2. REMOVE COLUMN HOLE COVER SILENCER SHEET (See page SR-9) 3. DISCONNECT NO. 2 STEERING INTERMEDIATE SHAFT ASSEMBLY (See page PS-21) 4. DISCONNECT NO. 1 STEERING COLUMN HOLE COVER SUB-ASSEMBLY 5. REMOVE FRONT WHEEL 6. REMOVE ENGINE UNDER COVER LH 7. REMOVE ENGINE UNDER COVER RH 8. REMOVE FRONT STABILIZER LINK ASSEMBLY LH (a) Remove the 2 nuts and front stabilizer link LH. HINT: Use a 6 mm hexagon wrench to hold the stud if the ball joint turns together with the nut. 9. REMOVE FRONT STABILIZER LINK ASSEMBLY RH HINT: Use the same procedures described for the LH side. 10. DISCONNECT TIE ROD END SUB-ASSEMBLY LH (See page DS-6) 11. DISCONNECT TIE ROD END SUB-ASSEMBLY RH (See page PS-21) 12. DISCONNECT PRESSURE FEED TUBE ASSEMBLY (See page PS-21) 13. DISCONNECT FRONT SUSPENSION NO. 1 LOWER ARM SUB-ASSEMBLY LH (See page SP-22) 14. DISCONNECT FRONT SUSPENSION NO. 1 LOWER ARM SUB-ASSEMBLY RH HINT: Use the same procedures described for the LH side. 15. REMOVE FRONT FLOOR PANEL BRACE (See page EX-2) 16. REMOVE CENTER EXHAUST PIPE ASSEMBLY (See page EX-2) 17. REMOVE HOOD SUB-ASSEMBLY 18. REMOVE NO. 1 ENGINE COVER SUB-ASSEMBLY 19. SUSPEND ENGINE ASSEMBLY (See page MX-19) 20. REMOVE NO. 1 HOOK (See page PS-22) 21. REMOVE FRONT SUSPENSION CROSSMEMBER SUB-ASSEMBLY (See page PS-22) 22. REMOVE FRONT NO. 1 STABILIZER BRACKET LH (a) Remove the 2 bolts and front No. 1 stabilizer bracket LH from the suspension crossmember. 23. REMOVE FRONT NO. 1 STABILIZER BRACKET RH HINT: Use the same procedures described for the LH side. 24. REMOVE FRONT NO. 1 STABILIZER BAR BUSH (a) Remove the 2 No. 1 stabilizer bar bushes from the stabilizer bar. 25. REMOVE FRONT STABILIZER BAR
You can download the manual online for about $15. Well worth it.
Jun 30, 2009 | Scion TC Cars & Trucks
Front left suspension went out.
do you mean the front shockabsorber some call it a strut.
Jun 26, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Hyundai Excel Rear Supension 99-2000 model
SUSPENSION REASSEMBLY
1. Apply the specified grease to the inside of the left suspension.
2. Using special tools (09555-21100, 09555-21000), drive bushings, into the suspension arm.
CAUTION
1) Apply grease to all outside surfaces of bushings.
2) Drive bushing in until the notch on the special tool
(09555-21000) reaches the end of the suspension arm.
3. When replacing the dust cover, insert a new one up to the center position (stopper) of the right suspension arm.
4. After applying grease to the surface of the right suspension arm, install the rubber stopper.
5. Slowly push the right and left suspension arms together. Wipe away the surplus grease. Align the marks on the stabilizer bar and the stabilizer bar bracket.
6. Install the rubber bushings, fixtures and washers.
7. After aligning the fixtures with the suspension arms according to the alignment marks, loosely tighten the nuts.
CAUTION
1) Install the washers and fixtures in the correct direction
and position as shown.
2) Tighten the nut to specification with the vehicle lowered
to the floor.
8. Pack grease in the dust cover and lips, and secure the dust cover with the clamp.
Jun 21, 2008 | 1994 Hyundai Excel
Steering vibrates over 30 mph.
I would look at changing out your bushes. do both sides as if this happend on the right you can bet your bottom dollar that the left will soon go as well. While you are at it check your shockabsorber mounts.
Jun 18, 2008 | 2002 Daewoo Lanos
Lands Phones Logo
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
