Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
How can i put my linksys 54G a password - Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
    President:
  • 524 Answers
  1. Using the "Quick Installation Guide", follow the instructions in step 1 toset up your new wireless router. You may also need to restart your computer inorder to see the router.
    Note: If you normally use a static IP address, you will have toreconfigure your internet connection to use DHCP. Go into the controlpanel and open your network connections. Edit the properties of your currentnetwork connection, and make sure that "Obtain an IP address automatically" isenabled.
  2. Connect to the router using your web browser by typing"http://192.168.1.1" into the URL address box.
  3. Leave the Username field blank, and enter the password "admin" to accessyour router when the login prompt appears.
    Note: You will notice immediately a list of menu options (Setup, Wireless,Security, etc.), and as you click on each of these submenus appear. Thisdocument will refer to a menu-submenu combination as Menu -> Submenu.
  4. Setup -> Basic Setup. In the "Internet Setup" section, choose"Static IP" from the drop down menu. Fill in the appropriate values thatdescribe your network. (You don't need to change anything in the optionalsection just below that.)
  5. In the "Network Setup" section, you should at least set your timezone toEastern Time, although you may make changes to the DHCP server as well if youanticipate more than 50 users connecting to your network at once.
  6. Wireless -> Basic Wireless Settings. Set the Wireless networkmode to "Mixed" if you would like both B and G clients to be able to connect toyour network. Otherwise you can just select "B-only". The "Wireless NetworkName" will be provided by CNS. Make sure that you disable "WirelessSSID Broadcast" to give a little extra securihow can i put my linksys 54G a password - wireless-basic.pngg src="http://i.fixya.net/uploads/images/wireless-basic.png" alt="wireless-basic.png" class="h_mi" />
  7. Wireless -> Wireless Security. CNS recommends that you use atleast WEP based security to protect your network. Choose WEP from the dropdown menu and then select "128 bits 26 hex digits" for the "WEP Encryption".Enter a passphrase into the "Passphrase" field and click "Generate" to generatethe corresponding HEX keys. Distribute key 1 to how can i put my linksys 54G a password - wireless-security.png key foryour network.
  8. Wireless -> Wireless MAC Filter. CNS also recommends that youuse a MAC address list to filter access to your network. Click the "Edit MACFilter List" and add all the MAC addresses that are going to be accessinhow can i put my linksys 54G a password - mac-filter.png Any time a new user requires access, you will have to add them tothis list.
    mac-filter.png IMPORTANT NOTE: Make sure that you add the MAC address of thecomputer you are using to set up your router first, before enabling this filter.Otherwise you will be unable to access the router and will have to reset therouter. If you do have to reset the router because you have locked yourselfout, there is a small reset button on the back of the router that will resetthe router.
    Once the appropriathow can i put my linksys 54G a password - wireless-macfilter.pngeen added, "Enable" the filter, andchoose the option "Permit only PCs listed to access the wirelessnetwork".wireless-macfilter.png
  9. Administration -> Management. You should make sure you changeyour password on this screen. "admin" is not a secure password! Also,you should disable "Remote Router access" so that your router cannot beconfigured from outside your network. UPnP is a protocol that opens ports inyour firewall on the flyhow can i put my linksys 54G a password - administration-management.pngeat. We recommend thatyou disable this, but if you are running applications like MSN video chat, youmay have to have this enabled.
  10. Administration -> Log. If you would like to keep a log ofconnections to your network, enable the logging here.
  11. That's it! You should be on the air!
Posted on May 03, 2010
I need to reset the password on my linksys Wireless GBroadband router WRT 54G without ruining my wireless set up in my house!
Use an Ethernet cable to connect your computer directly to the router.
Access the web-server "inside" the router.
Login to the router, with the current ID/password.
View the wireless settings:
* SSID
* encryption-level ('WPA' or better, please)
* network password
and change it, if you need to.
Feb 21, 2011 | Linksys Wireless-G Broadband Router
Hya#was wondering could you tell me how 2 lock my wireless router, i run the pc and a laptop, but wud like it locked, thanx
you need to login the router in the address bar... the address depends on the make of the router, typically it's 192.168.1.1 for linksys. I would google Belkin (model#) password. and it will give your default username and password for your specific router. If somebody has already taken over your router just unplug it for a minute or press the reset button on the back. Resetting the power on it puts it back into default login, so now you want to change the administrator password after you login the router from the web address bar.
Dec 10, 2010 | Belkin (54G F5D7230UK4) Wireless Router
Just had a new wireless card fitted and I am trying to connect to my router
I recently purchased a new wireless card for my desktop, it was a Linksys 54g with speedbooster but after the switch the networks I was connecting to (Free wireless from my apartments) will no longer connect. The old card that I had was just an offbrand card which used the microsoft zero connection tool to configure, this new card attemps to use the software included and ive tried to switch between the two different connection configuration tools both can detect the routers but when trying to connect it does not even get to the aquiring access key stage. the router is not passworded so I guess I was just wondering can this new card not connect to the router maybe due to brands? possibly the router is belkin or something of that sort and this linksys card cannot connect? I had before gotten it to connect at the very good 54kbps or whatever the number is but it would not let me access internet and then said limited/no connectivity. I also tried to change the settings on my wireless card and set them to 802.11b only, 54g auto, 54g LRS or Performance but all had the same result, I switched the default channel to match that of the router as well still nothing.
dell inspiron 1525 battery
Oct 03, 2010 | Dell Inspiron 1525 Laptop
Lost my password and cannot connect new netbook
hi
  • If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
    To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
  • Step 2reset-password-linksys-router-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a02/2p/6m/reset-password-linksys-router-1.2-800X800.jpg'); }); Once your router is hard reset, you will need to login and reconfigure it again.
    To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
    LinkSys Default Password
    On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
    Once you are past the login screen, you are able to reconfigure the LinkSys router.
    You want to go to the management tab and change the administrator password to something else to keep others from accessing your router.
  • Step 3 After changing the administrator password then you will need to enable WEP or WAP security so your nosy neighbors aren't tapping into your wireless network. I am picking up 4 networks with my pc antenna.
  • Jul 21, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
    I have a linsky wireless G 2.4 Ghz 54Mbps (model WRT 54G) I have the cd, but I do not have the password. I am not sure if this is the reason, I can't set up my network. How do I get another password
    Linksys WL router always has default password "admin" you will have to reset router to factory defaults by plugging Pin in to Tiny Hole on Router back side for 5 seconds. and then login by default ID "admin" and password "admin" to configure router again. [Remove Inverted Commms from User name password while entering
    Mar 09, 2010 | Linksys Wireless-G Broadband Router
    Have a WRK-54G Linksys wireless router. Have a
    I had a TEW-421 card for a time, and it can not do WPA encryption, only WEP. It's not a driver shortcoming, it's the hardware in the TEW-421 card.
    Sorry to tell you it's a dead-end, but at least now you know.
    Oct 18, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
    I HAVE FORGOTTEN MY NETWORK KEY FOR LINKSYS WCG200 ROUTER AND WANT TO ADD WIRELESS LAPTOP. hOW DO I FIND IT?
    Put a direct line into the router and open an internet window. In the search bar type 192.168.0.1 and it should take you inside your router. you can see your password there
    Jun 12, 2009 | Linksys WCG200 Wireless Cable Modem 54G...
    1 forgot my passwords for each computer on linksys router 54G
    You can press the reset button on the back for a minute and it will reset the router back to default.
    Apr 04, 2009 | Linksys Wireless-G WRT54G Router
    Vista keeps losing internet connection
    open device manager and  look at network adapters and right click on your device and go to properties and uncheck the power management box that allows pc to put device to sleep. this should resovle your problems since windows id defaulted to put device asleep when idle to save power. hope this helps.
    Mar 14, 2009 | Linksys WCG200 Wireless Cable Modem 54G...
    Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
    112 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
