Question about Haier hwr10xc6 Air Conditioner
Show me where the drain is haier 10xc6 - Haier hwr10xc6 Air Conditioner
Haier AC window unit showing code "EO"
It's a "drainage system trouble" code.
The compressor run light flashes in 10 flash increments.
You should be able to check whether condensate is draining from the unit.
If not draining, that's your problem.
Sep 13, 2017 | Haier Heating & Cooling
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
How to drain water from haier 8000bt portable ac
There is a drain plug on the rear of the unit, just above floor level. Before draining into a low sided pan of bowl, capable of holding 1 quart of water, turn the unit OFF & unplug it.
Another draining option is to disconnect the exhaust hose(s) and roll the unit to a floor drain or outside to drain it.
Hope this helped you and thanks for choosing FixYa.
Sep 22, 2011 | Haier Heating & Cooling
Hi,i can not use my air conditions ,i turned to warm mode,it show "E". its haier brand
Hello
the code is drain problem, your drain pipe could be blocked.
Please let me know if its a diff-rant code can help with all the fault codes
Thanks
Jun 08, 2011 | Haier Heating & Cooling
I bought my Haier HWR 10xc6 mid summer of last year. Used it for two weeks and it was fine. Didn't use it much as went out of town the rest of that summer. I turned the unit on last week and set the...
Hello, it can be a few things. 1) plugged air filter and evaporator coil 2) low refrigerant charge 3) the compressor is not engaging If you are willing to check out a few things i can tell you exactley whats going on with your ac
Jun 07, 2011 | Haier hwr10xc6 Air Conditioner
Water is running out of the machine as soon as it is filling. What should I do and whom should I contact?
This shows that the drain is not closing and allowing the water to drain off. Remove the drain valve/pump and clean or back-flush , check if the pump is working if not replace.
Mar 30, 2011 | Haier Washing Machines
Haier CPN10XC9 leaking water. Have drained the
I had the same problem, removed rear cover (15 screws) and found a drain slot under the conderser plugged with dust and grime. gently cleaned the slotted area out with a Q-tip, and the condensate is now following the proper flow into the tan and evaporator. It has been running for 2 hours with no drips!!
Jul 17, 2010 | Haier CPN10XC9 Air Conditioner
Air Conditioner/Heater not working for more than 2 hours.
If you are running it in a very humid envioronment then it will make more water than it can evaporate off.
Nov 10, 2009 | Haier (HPE09XC6) Air Conditioner
Error code
Do you still the warranty for this unit? maybe you should contact the company which you bought the unit.
May 31, 2008 | Haier hwr10xc6 Air Conditioner
Pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Feb 03, 2008 | Haier HDP18PA Stainless Steel...
Haier hwr10xc6 Air Conditioner Logo
78 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
