Question about Brother MFC-5840CN All-In-One InkJet Printer
Printer won't print
My Brother MFC 5440/5840CN printer does not print, even though the print queue indicates that it is printing. I suspect that the printer is somehow off-line. The printer display has a blinking cursor that says "Res standard." I have been unsuccessful in cycling through the Menu function to find some sort of Ready to Print option, but nothing comes up. Also, I have tried turning the machine off by holding the ON/OFF button down as the User Guide instructs, but it stays on and only responds with three beeps. Nowhere in the documentation are beeps defined, so I am at a loss as to what these indicate. Pressing other buttons also results in beeps. It might be helpful for you to know that I am running Windows XP Media Center edition, Version 2002, Service Pack 3. I will be most grateful if someone can be of assistance. This is a used printer that was given to me and I would like to get it to work. Thanks!
  • blong625 May 03, 2010
    I have no "mono Start" button. ???? Right now all my buttons are flashing (fax, scan, copy).
  • 2,427 Answers
Try this
- Unplug Machine
- plug in the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press the "stop" button.
- press “99” to exit the maintenance mode.
in that fails
Unplug Machine
select factory reset..
unplug usb cable from pc
click start, printers and faxes
delete old brother printer
plug in usb cable ,, it will install a fresh copy of the driver..
Posted on May 03, 2010
  • computersale Jul 29, 2011
    I have an MFC5840CN, and these instructions were the first ones I found that were entirely accurate for my machine. these worked the first time I tried them, and I was able to get back to printing. I found similar instructions in a different order that DID NOT work. Now I need to find out how to remove that ink reservoir/rank and empty and replace it. Thanks!
  • 712 Answers
Check if it has employed any paper jam. Or else, try cleaning or replacing your drum and put it back again. See if it works.
Outlook won't print to Brother MFC7360N AllInOne Laser Printer
Must be set on Brother MFC-7360N series. Set on PC-FAX will not print with all programs, as it is printing with an output through the fax. Go to control panel, select devices, printers to change to pc-7360 series. This should print on all programs.
Mar 17, 2014 | Brother HL-5240 Laser Printer
Brother MFC prints blank pages
Try disconnecting power completely, not just turning off. Wait a few minutes and reconnect to power
Also, your print queue may be full with failed attempts at printing. The printer becomes confused and does not know what to print next. You should be able to flush the queue at the computer, but the complete disconnect and reconnect may accomplish this
Sep 04, 2012 | Brother MFC-790CW Multifunction Printer
How to clear print data on a brother printer
(make sure you have the printer turned off) otherwise it might print another page if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a display print queue tab you can see all prints right click on the ones you don't need select cancel
hope this helps
Jun 13, 2012 | Brother MFC 210C All-In-One InkJet Printer
Hos to clear the printer queue in a Brother MFC 620 CN printer
Not sure what version of windows you have but this should work.
First remove the paper tray so it stops printing. Click start and chose control panel, go into the printer section. Locate the brother, you should be able to see how many documents are in queue. Right click the brother and chose cancel all documents.
Jun 15, 2010 | Brother MFC-620CN All-In-One InkJet...
My yellow toner is out and the printer will not print in just black
The MFC-9440CN should be able to work even if one or more of the color cartridges are empty.
here's what you can do to print in black only.
1. Unplug the power to the MFC-9440CN
2. Clear the print queue on your computer so that there are no jobs waiting.
3. Right click on the MFC-9440CN printer icon and select "printing preferences"
4. Select "mono" as the color mode.
5. Turn the power back on for the printer.
Now when you print it will be in black only and it should work even if all 3 colored toner's are empty.
Thanks,
Pat
Mar 26, 2010 | Brother MFC-9440CN Laser Printer
Can't address envelopes using Microsoft Word 2007 & Windows 7
Excellent question. Wish I had the answer. I have the same problem with the MFC-7440N. I hook up my old HL 1240 and it prints them fine, so I now use two printers - one for envelopes and one for normal printing. I contacted Brothers and was told that it was not the printer, but the Application. If so, then why does my old Brothers printer work? They do not have the answer.
Feb 24, 2010 | Brother MFC-7440N Laser Printer
My 5 in 1 printer is saying no cartridge when I just replaced it and when I do get it to print it's not printing that good at all kind of gray like it's out of ink, it has a new cartridge
  • Click open START then CONTROL PANEL then PRINTERS AND FAXES
  • If asked, click the link that says view or modify existing printers
  • You should get to a window that shows a list of printers that are installed on your computer
  • Look for the printer icon with a tiny little checkmark in a black circle to the upper right (see image below). This is your default printer, that is, it's the one that prints if you don't manually select a specific printer. defprint.jpg
    Note how the checkmark indicates that the Brother HL-2040 Series is my default printer
  • In most cases, this is the printer you are having trouble with, but the following procedure can be applied to any printer on your system.
  • Double click open your default printer to view the print queue printqueue.jpg
    Note that there are two documents waiting to print in my print queue
  • If the print queue is empty, skip the next step
  • Click and pull down the PRINTER menu from the top of the print queue and select CANCEL ALL DOCUMENTS. This will delete anything that's stuck in the queue cancelall.jpg
    After clicking CANCEL ALL DOCUMENTS, it may take a minute or two for the queue to completely clear
  • Click and pull down the PRINTER menu from the top of the print queue. If there is a line item that says USE PRINTER OFFLINE and there is a checkmark to the left of it, click it once, otherwise, click CLOSE.
  • Now go to the printer and power it off, wait a few seconds and power it back on.
If these steps haven't solved your printing problem, then you probably need help
Oct 01, 2009 | Brother Multi-Function Center MFC-240C...
Same Problem - Printer Says Offline
try reinstalling all drivers,, and cancell all prints. before.. take an test print from , control panel ---printer-- print a test page..
Sep 27, 2009 | Brother MFC-410CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
317 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
