Question about Sony VAIO VGC-RB50 PC Desktop
I have a VGCRB50 G desktop pc , when I try to power up the pc,I only get a green light blinking on the back of the power supply, is it the power supply or motherboard?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 50 Answers
I have encountered that problem before. What I did is to remove the RAM and put it back again then I see the windows running. Just try it men, just be sure to unplug it first.
Posted on Jun 11, 2010
Vaio desktop blinking power supply
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector and next to a green blinking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
If the steps above don't work you will need to get a new power supply.
May 19, 2012 | Sony VAIO VGC-RB42G PC Desktop
Will not power on, green light blinking on back
A blinking green light means your power supply needs changed
Jul 02, 2011 | HP Compaq Presario SR1503wm PC Desktop
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
My vaio wont turn on and the green light in the back keeps blinki
The green light blinking in the back indicates that the power supply went bad and is not turning on, go ahead and get the power supply replaced. Normally that light is supposed to be fully lit and green.
Apr 28, 2010 | Sony VAIO VGC-RB53 PC Desktop
Bestec model atx 250 12z flashes green when hp pavilion a706n is powered on light on back blinks green and pc does not power on even after all cables are disconnected
Try these suggestions:
<a href="http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&cc=us&lc=en&dlc=en&product=427167&dlc=en&lang=en#bph06788_section_2" >Troubleshooting Power Supply Issues</a>
Nov 29, 2009 | HP Pavilion a706n PC Desktop
Sony VAIO VGC-RB42G - No Power; Blinking green light on power
Try a different known working power supply on that computer, the green light on the power supply should be constant and not blinking. The green light on the motherboard shouldn't be blinking either but if its not getting the right voltage from the motherboard then it will blink as well.
Get a different power supply and see what happens. At that point the power supply green light should be constant, if its not then your motherboard is faulty at that point, if yout the green light is blinking on your motherboard, if both are constant then reseat the memory and CPU and only have the power supply hooked up to the motherboard and not to anything else.
If you still can't get video then at that point you know the motherboard is definitely bad.
Aug 30, 2009 | Sony VAIO VGC-RB42G PC Desktop
Blingking light on my motherboard, no power.
Chances are your power supply and computer is fine! From other forums on this problem (which I also had), I've learned the following:
1. If you unplug the computer for a half hour or so (the blinking green light will gradually slow down and quit) and plug it back in, the situation will correct itself and the green light will be steady; however if this does not work,
2. a reset that works for a lot of people with the blinking light problem involves leaving the power supply plugged in and unplugging the power supply connection at the motherboard (it usually also has a blinking green LED) and plugging it back in. To read up on how to do this, Google "blinking green light on computer power supply" and read through some of the forums and you'll come on more specific instructions. Usually, you have to wade through everybody telling you to replace the power supply or your motherboard is fried. It's worth a try for a quick fix, just in case those situations don't apply!
May 30, 2009 | Sony VAIO VGC-RB42G PC Desktop
Will not pwer up. Greenlight blinking on back
The green blinking light can mean there is a problem with the power supply.
Try unplugging the computer from the wall, and turning on the pc on switch.
After a few minutes, try plugging it back in.
If that does not start things up, you may have a bad power supply.
If the power supply is bad, these models take standard power supplies. You should get an ATX 350Watt or higher power supply.
They are easy to replace, unplug the power from the wall, disconnect all the cables inside the computer. Unscrew the four phillips screws outside the back of the computer where the power supply is attached to the case.
Remove and replace.
If you don't feel comfortable with this, a good local computer shop can help you out.
Apr 13, 2009 | HP Compaq Presario SR1330NX (PP161AA) PC...
Computer wont start up. Blinking green light in the back of tower
I've had that happen twice to my Vaio desktop and there was a very easy fix. I'm not a techie, but I found a recommended solution online when this first happened six months ago. I couldn't find the solution again, but I fortunately remembered the steps.
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector andnext to a geen blnking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
It worked twice for me; I hope it works for you.
Mar 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
Sony VAIO VGC-RB50 PC Desktop Logo
233 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
