Question about Digi 500 Gram X 0.1g tal Pocket Scales Drug Scale Jewelry
How do I calibrate my fuzion edge-500 digital mini scales?
  • 6 more comments
  • Jemma Sheikh May 03, 2010
    What's the best way to test their calibration?
    How can I test their calibration?
    What if I don't have actual weights? Can I use pennies or something? How much does a penny weigh?
    How much do pennies weigh? I need 2 know if my fuzion edge-500 digi mini scales are out?
    What about sterling? Ie: a 1p or 2p coin.
    Thank you for that. How much would a 1 penny piece weigh? (£0.01)
    Thank you so much for your help, my scales are right as far as I can tell which is wonderful news! Thanks again!
  • 8,197 Answers
The weights of a penny depends on their dates.
Indian Head pennies dated 1864 to 1909 weigh 3.11 grams.
The Lincoln, Wheat Ears Reverse penny weighs 3.11 grams except for steel cents made only in 1943 that weigh 2.67 grams.
The Lincoln, Memorial Reverse penny (1959 to mid 1982) weighs 3.11 grams.
The Lincoln, Memorial Reverse penny (mid 1982 to present) weighs 2.5 grams.
It's not easy to tell the 1982s apart, so to figure out how many cents weigh a pound (or any other amount) you'd have to decide which date range you wanted to use and eliminate all 1982 coins. To help, a pound is 453.6 gm so just divide that by the weight of the penny date that you decided to use.
Posted on May 03, 2010
  • 2 more comments
  • Jyackle5
    Jyackle5 May 03, 2010
    You would like to know what a 1 or 2 pound coin also weighs
  • Jyackle5
    British Sterling 1 Pound (coin) weigh is.
    9.5 grams and are made from 70% copper, 24.5% zinc and 5.5% nickel.
    Is that what you would like or would you like something different.
  • Jyackle5
    British decimal general circulation coins are dimensioned as follows:
    1 Penny (from 1968 - 1991) 20.32 mm diameter, 1.52 mm thick, weigh 3.56 grams and are made from 97% copper, 2.5% zinc and 0.5% tin. The edge is plain.
    1 Penny (from 1992) 20.32 mm diameter, 1.65 mm thick, weigh 3.56 grams and are made from copper plated steel. The edge is plain.
    2 Pence (from 1971 - 1991) 25.9 mm diameter, 1.85 mm thick, weigh 7.12 grams and are made from 97% copper, 2.5% zinc and 0.5% tin. The edge is plain.
    2 Pence (from 1992) 25.9 mm diameter, 2.03 mm thick, weigh 7.12 grams and are made from copper plated steel. The edge is plain.
    5 Pence (from 1990) 18 mm diameter, 1.7 mm thick, weigh 3.25 grams and are made from 75% copper and 25% nickel. The edge is milled.
    10 Pence (from 1992) 24.5 mm diameter, 1.85 mm thick, weigh 6.5 grams and are made from 75% copper and 25% nickel. The edge is milled.
    20 Pence (from 1982) 21.4 mm diameter, 1.7 mm thick, weigh 5 grams and are made from 84% copper and 16% nickel, and are seven sided. The edge is plain.
    25 Pence (from 1972 - 1981) 38.61 mm diameter, 2.5 mm thick, weigh 28.28 grams and are made from 75% copper and 25% nickel. The edge is milled. During their period of issue, they were referred to as a Crown due to them being of the same dimensions as the pre-decimal Crown coin. These coins were discontinued from 1982 but remain legal tender. Circulation of these coins is uncommon.
    50 Pence (from 1997) 27.3 mm diameter, 1.78 mm thick, weigh 8 grams and are made from 75% copper and 25% nickel, and are seven sided. The edge is plain.
    1 Pound (from 1983) 22.5 mm diameter, 3.15 mm thick, weigh 9.5 grams and are made from 70% copper, 24.5% zinc and 5.5% nickel. The edge is milled with incuse lettering or ornamentation.
    2 Pound (from 1986 -1996) 28.4 mm diameter, 3.1 mm thick, weigh 15.98 grams and are made from 70% copper, 24.5% zinc and 5.5% nickel. The edge is milled with incuse lettering. Circulation of these coins is uncommon.
    2 Pound (from 1997) 28.4 mm diameter, 2.5 mm thick, weigh 12 grams and are bimetal made from 76% copper, 20% zinc and 4% nickel in the outer ring, and the centre is 25% nickel and 75% copper. The edge is milled with incuse lettering.
    5 Pound (from 1990) 38.61 mm diameter, 2.89 mm thick, weigh 28.28 grams and are made from 75% copper and 25% nickel. The edge is milled. Intended as a souvenir or collectible, but occasionally seen in circulation. These coins are now referred to as a Crown due to them being of the same dimensions as the pre-decimal Crown coin.
    The following are specifications of British decimal coins which have been demonetised and are no longer legal tender. Unless they are uncirculated or Proof, they have minimal collector value.
    Half Penny (from 1971 - 1984) 17.14 mm diameter, 1 mm thick, weigh 1.78 grams and are made from 97% copper. The edge is plain.
    5 Pence (from 1968 - 1989) 23.59 mm diameter, weigh 3.25 grams and are made from 75% copper and 25% nickel. The edge is milled.
    10 Pence (from 1968 - 1992) 28.5 mm diameter, weigh 11.31 grams and are made from 75% copper and 25% nickel. The edge is milled.
    50 Pence (from 1969 - 1996) 30 mm diameter, 1.78 mm thick, weigh 13.5 grams and are made from 75% copper and 25% nickel, and are seven sided. The edge is plain.
  • Jyackle5
    You are welcome. Sorry for not getting it for you the first time. I did not know you wanted the pound weight. Not the american penney weight.
  • 10,865 Answers
Hello. Your scale has an autocalibration feature. It should calibrate itself. If it is off, your only option is to replace it. Joe
  • Joshua Smith
    Joshua Smith Sep 28, 2016
    Do I set it on grams to weight .25
  • 2,427 Answers
Ok you need these weights first
1.) 5 gram / 5 ounce
1.) 10 gram / 10 ounce
1.) 1 gram or one ounce
under the sacle is the caliberation screw,, place the 1 ounce or 1 gram weight and turn the screw until it says 1,, repeat for 5 and 10 g / ounce weight as well
thats it your done..
How to calibrate mgp-1014
There are different digital scales available for the home, or in your business (like your kitchen scale, bathroom scale, weight scale or food scale), but you have to calibrate them first before you can use them. There are different brands of digital scales like Primo and Tanita, and each of these brands has different instructions on how to operate them for calibration.
Infor from: OBD diagnostic tool one stop supplier
Mar 06, 2014 | 760Li Brief instructions f01, f02, f03....
Fuzion RT500 professional digital mini scale user manual
Starting with the unit off. Press the power button and hold down until it starts to cycle through the weights.
Feb 07, 2013 | Health & Beauty
Find fuzion digital scales fz-75 instruction manual
I have written reviews on GE HDTV antenna, please read this http://usemyreviews.com/ge-24769-outdoor-antenna-digital-hdtv-futura/ GE 24769 Outdoor Antenna for Digital HDTV Futura
Jun 05, 2012 | Office Equipment & Supplies
I have a Ohaus gram scale Model N06112 and all the read out says is error code 9.8 and is unresponsive to pressing any of the buttons????
Your problem may have a simple fix. It is called a manufacturing calibration. Unfortunatly it is a little too complicated to answer in this forum. If you will email techsupport@ohaus.com I may be able to help you.
Ohaus Technical Support.
Dec 18, 2010 | Life Science Ohaus Ya-501 500 X 0.1 Gram...
Hi I got a fuzion scale sx-500 and I need to re calibrate it I don't know how Do it
Hold power button, while holding press 'M' twice. Release the power button, press once more and it should say PASS if not then there's a problem.
Mar 16, 2010 | Health & Beauty
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
CALIBRATING A TANITA KD-200-110 DIGITAL SCALE.
According to Tanita, you must send the scale back to the factory to adjust the calibration. As of September 2011 the cost is $125.00
This is more the scale costs.
Moral of the story. Don't buy Tanita.
Aug 24, 2009 | Tanita 1479V - Digital Pocket Scale /...
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Mini digital scale displays out2
I just had this problem on set Salter scales (says 3309 on label on back so assume that's model no) which came up OUT2 solidly after hadn't been used for a while.
Looking on WWW this means on other scales they need to be recalibrated. There are only 2 buttons on ths model ON/Zero and 2nd is mode for grams, oz etc. Discovered by trial and error have to hold down the on button and repeatedly click the measure button as it powers up, screen says err2 press on button again and says 5000g, put 5000g weight on scales, press on button again display says CAL press on button and it at first came up with EEEE and failed but next attempt it said PASS and it all worked again. I used 2 x 1.5kg bags flour and 2 x 1Kg bags sugar to make 5kg with bit tipped out of one to make exact and checked on another set scales. So trick appears to be finding how to get your scales in to calibrate mode and what the weight it expects is.
Jun 15, 2009 | Balance Health & Beauty
Digi 500 Gram X 0.1g tal Pocket Scales Drug Scale Jewelry Logo
911 people viewed this question
Top Digi Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Digi Health and Beauty Expert? Answer questions, earn points and help others
