Question about Frigidaire FAP094P1Z Portable Air Conditioner
Noise When it becomes noisy, is there any way i can fix it? It keeps rattling on and off. Please help.
  • 10,865 Answers
Hello. Try to determine where the rattling is coming from. If it is a loose grate, attach it with some construction adhesive. If it is a loose fan blade you may have to replace the fan. Joe
Posted on May 03, 2010
Dryer rattles
sometimes a blower wheel will become worn out on the motor shaft and just spin freely cusing very noisy and no air movement causing overheating
Nov 23, 2013 | Dryers
Exhuast to noisy needs flexi pipe
Rattle noise is hiting something? Yes you can buy on line a flex pipe or a mufflet shop will fix it. But if it rattles inside it could be your catalyst
Feb 27, 2013 | Daewoo Cars & Trucks
My 1998 sebring 6cyl makes a metal on metal noise on the side of my engine by the belts i tried greaseing all the pullys and i used belt noise sparay but it becomes lower and then it becomes higher ???...
sounds to me from the brief description like you have either a water pump rattling, or a timing chain coming slack. Is the noise coming from the alternator? Never grease pulleys, ever. also the stop squeak spray is bad for your belts. Don't know why they even sell it. If you listen carefully you may be able to pin point the rattle. Is this a tick tick tick, or a rattle rattle rattle? Does sound like a water pump rattle or timing chain slap though. Hope this helps
Jan 14, 2013 | Cars & Trucks
Rattle noise
if you just got it check for packing material stuck around the fan area
if there is nothing , then take it back for a warranty exchange as it is not as described ---quiet
Jun 26, 2017 | Honeywell Humidifiers
I am getting a loud rattling noise. could this be my compressor
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Jan 29, 2010 | Frigidaire Refrigerators
Loud clanking noise when washer is coming to a stop
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
May 19, 2009 | Whirlpool LSR5132PQ Top Load Washer
Making lots of noise when running help? please kenmore refridgerator model 25368821790
Hi
Please revert for further assistance and Do accept the solution if found useful.
Thanks
Rylee
Mar 18, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kitchenaide Microwave KHMS145KSS rattling noise
there is a possibility that sme of the wireing or the fan has become loose best checking it .
Jan 01, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Noisy Fridge!
you need a new compresor that type of work will run you like 4 to 5 G'S you are better off buying a new one. i repl compressors everyday i work for one of the major companys that go to your home to repair refrigerators
Oct 15, 2008 | Refrigerators
Marvin 5460
Returned to home depot. Fan was broken.
Feb 08, 2008 | Marvin Quartz Radiant Heater
Frigidaire FAP094P1Z Portable Air Conditioner Logo
354 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
