Question about Refrigerators
Samsung fridge SR394NW and every thing in the fridge is freezing
We have a samsung fridge SR394NW and every thing in the fridge is Freezing
  • legacy198286 May 11, 2010
    make sure u have the dials set on factory settings
  • 5 Answers
SOURCE: Samsung Fridge Freezer
Possible bad defrost timer.
Posted on Mar 09, 2008
  • 400 Answers
SOURCE: Liebherr fridge 3150 keeps freezing
The problem is the thermostat, not the drainhole. The thermostat should stop the compressor when a setpoint temperature has been reached, this gives the unit a chance for a small defrost.
Posted on Mar 05, 2009
SOURCE: the fridge part of my fridge freezer keeps freezing everything,
I tried solution 1 without success, so I resorted to switching the whole unit off at night and on in the day to stop it freezing up. After about a week of doing this it started working properly again. One month later it is still OK
Posted on Mar 20, 2009
  • 14 Answers
SOURCE: Amana arb2557cw condenser coils freezing, fridge not cooling
There are a few things that it could be. Do you mean the evaparator coil? This would be the coil on the inside of the freezer, the condenser is outside the unit. If the evap. coil is freezing, you could have to much in your freezer blocking air flow. You could also have a evap. fan not running. Check the owner's manual for the location of the defrost timer, it could be bad. The thermostat needs to be checked and set so that it is at a reasonable level. One last thing to check would be the condensate drain. Make sure the drain is not plugged or the line is not plugged. Good luck.
Posted on Jul 31, 2009
  • 93 Answers
SOURCE: Water setteling on bottom of freezer side and
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Posted on Sep 14, 2009
My refrigerator keeps freezing things...,.changed the gaskets around door and still have the freezing probkem
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link... refrigerator keeps freezing things Google Search
Oct 23, 2017 | Refrigerators
Why are vegetables freezing in crisper?
There is a control on refrigerator that controls the amount of cold air that is directed from freezer to refrigerator section. Locate that control and lower the amount of cold air going into refrig.
Oct 07, 2015 | Samsung RF265AA Bottom Freezer French Door...
My Samsung RL39WBMS fridge on m fridge freezer keeps freezing food. Why is this happening all the time and how can I prevent it?
maybe the fridge is set on a colder setting and if that's not it then stick it on the lower shelves and that might help from not freezing because are fridge is the same way when it is stuck by the coolant fan
Nov 02, 2014 | Refrigerators
Very noisy fridge, back wall freezing up
Possible bad freezer fan motor. I need more information such as brand and model number
Mar 10, 2014 | Samsung RS2630WW Side by Side Refrigerator
I AM HAVING A PROBLEM WITH MY SAMSUNG FRIDGE FREEZER THE TEMP INDICATOR KEEPS FLASHING AND ITS NOT FREEZING?
Oct 22, 2009 | Samsung Refrigerators
Samsung RB215BSSB refrigerator freezes up
I had a similar problem where my evaporator coil was freezing into a block of ice, which caused my fridge to warm up due to a lack of air flow. I fixed this by doing a few things. I replaced the circuit board ($100) which was easy to do. Unfortunately, this didn't fix my problem so I took the inner fridge cover off to view the evaporator/heater coil assembly. I checked my thermo fuse and found it to be open (failed). I ordered the thermo fuse and the thermistor and replaced them both. I then plugged the fridge back up and put a regular thermometer inside the fridge to get an accurate reading of inside temp. A few days now and everything looks good. The board, fuse, and thermistor were all pretty easy to replace.
Apr 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Side by side refrigerator freezing up
inside the fridge there is a cold radiator which has filled with condensation or water from freezing it when say cleaned out the fridge this can be remedied by letting set for a few days outside in the sun so that water can evaporate properly or you can call a repair man and he can pull out frost radiator inside and defrost all the water out by dry wet vac and heater dryer
ice builds apon ice even a little bit can build up to a mountain same thing happended to my top end whirlpool i pulled the metal grate and defrosted this by pouring tap water over the ice which it went down the defrost tube outside water drain this helped greatly havent had trouble with ice since
Apr 21, 2008 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
140 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
