Is my picture tube going?
My picture on my mitsubishi vs-5042 projection tv keeps cutting out after about 2 -3 hours of viewing. If I turn it off for an hour or so, it will come back on and last about 2 hours. Is the picture tube going or is a circuit overheating?
    Master:
  • 518 Answers
Most proj TV's of that type have 3 Picture tubes Red, Green and Blue. It's not likely that all 3 went bad at the same time in the same manner. So I believe you have a circuit problem, probably in the power supply stages, possibly a bad solder joint.
Hope that helps...
Geno
Posted on Mar 26, 2008
Tv keep jumping at the top. the picture is green
This is likely a problem in a section called the vertical drive. A number of small parts need to be replaced. The green colour is due either to weak red an blue tubes or the green tube is over-driving. You might want to rethink spending any money fixing this...
Mar 30, 2010 | Mitsubishi VS-5047 50" Rear Projection...
My mitsubishi vs-5042 when i turn on power i here it click on but does not show pic or sound
temexchic213 : I
Had the same problem with my vs-5042, take of the front cover for the speakers and unscrew the flat wood panel inside you will see some wires right in front like blue,white,yellow ect. wiggle those wires all over in their make sure the TV is on but be care full. It worked on mine i just had to find the right one. Good luck.
Oct 30, 2009 | Televison & Video
I have sound but no picture it is a mitsubishi tv projection tv vs-5042 I was told it may need to cleaned not sure how to clean it or if that needs to be done
Hello more than likely you have lost heater voltage to your CRT, also may of lost High Voltage, but usually when you lose HV the set will shut down. This model is notorious for open Heater voltage resistors.
Have a technician come out and confirm.
Sep 27, 2009 | Televison & Video
VS-5042 Sound but no picture
It is not bulb, are you talking about the tube ? At the neck of the tube you will see some connections.Carefully abserve if any cracks on the solderings(we call them DRY SOLDER), then connect them with soldering iron. Always make sure you have disconnected the TV from the mains. If the problem still persists, you will need to reffer to a qualified and Experienced person. He need to look for the LOT section(Auxiary power supply), video amplifier, CRT sections.
Aug 23, 2009 | Mitsubishi VS-45607 45" Rear Projection...
I have a mitsubishi vs-5042 projection tv. It's old but still working. Is there a capacitor kit I can buy for this tv? And or is there something else I can do to keep it going. The projectors are a bit...
To my knowledge there is no capacitor kit . With this sets age, you would have to replace way too many to count to even consider doing.
It was a very fine product for it's time, but it may be time to let it go in peace.
Jul 18, 2009 | Televison & Video
Mitsu vs-5042 Works then picture goes out. Thumping works sometim
If you occasionally have a picture then you stand a good chance of repairing this tv. There are bad grounds on the deflection board. Start with the board that has the flyback. I do not know the year of your tv. Sometimes the same model may have an option improvement than one couple of months earlier. The first suspected problem would be the vertical IC. In some cases this ic is located on the convergence board and in others the flyback board. It has seven pins and is the TDA version. Located on a large heatsink. Resolder this and any other grounds on both board. Some will tell you the P I P board is bad. This is a free standing board that can be removed and replaced. But please do the earlier option first.
Jun 28, 2009 | Mitsubishi VS-45607 45" Rear Projection...
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
My TV won't turn on...
check the power supply sounds like its going out
Jul 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Turns on then turns off
I had the same problem with my VS 45607,luckly I unplugged it for about 1 hour and tried it and thank God it's still working.
Jul 01, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
416 people viewed this question
Top Televison & Video Experts
