I turned my computer off to move to another location, unplugged my aopen monitor... when I replugged everything back.. my monitor would not come on... the power button is flashing.. but the screen is black
  • rooinekpilot Mar 06, 2009
    The power light start out green then after about a second gives one long orange flash followed by three short orange flashes. The problem occurred in a similar way to the post to which this question is attached in that the computer was moved several thousand miles. It sort of started up with something on the monitor but would not bot in the normal way. I thought is might be the small lithium battery and replaced it. No joy. I removed and replaced the RAM still not working other than the flashing power button. Suggestions please?
  • Dave MacPhee
    Dave MacPhee May 11, 2010
    After waiting a few mins, does it finally come on? (what is the model #)?
If the Monitor Power is flashing then there is no data signal reachign it from your CPU.If you are bale to, open the CPU, remove the memory chip RAM and re insert it. Be careful not to disturb anything els and ensure the memory is properly reinserted. If you are in doubt get someone qualified to do it for you
Posted on Sep 28, 2008
  • 67 Answers
Take a look behind the computer. If there is more than one monitor port, try plugging the monitor into the other one. Also, certain monitor cards are notorious for not staying in the slot if you move the plug from the monitor around, or even unscrew it. My best bet is that if you open the case (turn off and pull the power plug first, then touch the frame to release static, you'll see that the back of the card is pulled up a little, exposing the connectors on the bottom. Pull the card all of the way out and reseat it into the slot. If the card was not connected before it should be now. Good luck.
Posted on Mar 25, 2008
When I turn on computer, monitor says "signal not received"'
If you monitor has multiple inputs try to change the source of the signal. Maybe a button for input source.
Oct 05, 2015 | Computers & Internet
Hi had this same problem. unplug computer tower an use another screen, i used my tv. plug vga into tv an turn on computer. go to Control panel and then Devices. look for your monitor an uninstall it from computer. then shut down the compter unplug an replug back into your lcd monitor it will automatically reinstall it for you. hope that works. just a pain havin to move it!
May 07, 2013 | Computers & Internet
I have an AOpen monitor with an Intel PC. I moved my computer and when I finished plugging everything back in, the monitor says "No Signal Detected" I checked the plug several times, unplugging...
check to see if you were using a separate video card, you may be plugging monitor cable in the motherboard socket instead of the video card socket.
Feb 17, 2013 | Computers & Internet
I have a rebuilt computer with various parts, when it would boot up it would just come to a black screen where I could see my muse and move it but only had a black screen. I was told to unplug everything...
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) Sata make sure they have a secure connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust in its socket
if you physically remove your graphics to check the socket card restart your computer this should activate found new hardware wizard
hope this helps
Sep 19, 2011 | AOpen AX4SG-UN Motherboard
After the computer is left alone for awhile is will start flashing Acer on the screen and the power button will change colors from blue to an orange looking color. I have tried moving the mouse and...
The monitor is entering "standby" mode.
In Windows, click Start.
Click Control Panel.
Click Power Options.
Change the number of minutes before entering Standby Mode.
May 14, 2011 | Acer X193W LCD Monitor
Screen is tinged yellow
It sounds like you're going to need a new VGA/DVI cable. (from PC to monitor)
I suggest you try another one, then post back here if it doesn't fix the problem.
I hope this helps,
Jun 19, 2009 | Samsung SyncMaster 172N 17" LCD Monitor
Power light keeps flashing, unable to power up screen. Tried unplugging power source and turning off hard drive. Neither of or combo of worked.
Turn off the power to your monitor. Unplug from the back of your computer and for the outlet wait 10 to 20 minutes and reconnect and try to cut it on.
Jun 05, 2009 | AOpen F75PS 17" Flat Panel LCD Monitor
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Power problem
ok..I do believe thathe cable is connected to the monitor, right? have you checked your system unit if its also turned on? if it does, try to reseat your cable wire of your monitor( make it snugged fit and tight to avoid loose connections) then try to replugged it to the power source..
Jan 27, 2008 | AOpen A50P (Beige)
Stuck in power saver
Try the unlock procedure: With the monitor on press and hold the "MENU button for abot five seconds and see if it resets. If that doesn't work tell me a bit more about the screen - is there any OSD (on screen display) or error messages? Is the power indicator light on? If so, what color is it? Blue indicates that that you may need to turn the brightness and contrast up...\ If it is actually in power save the indicator light will be amber. What color is it? If the light is amber and all the connections to the computer are correct and it still won't come-up then it's an internal problem and the protect circuit may be keeping the screen from lighting. Good luck... And let me know. Bill
Jun 07, 2007 | LG L1722P 19" LCD Monitor
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
