Question about Acer Computers & Internet
No sound when connected to Samsung TV with SVGA monitor cord
2 Suggested Answers
  • 11 Answers
SOURCE: trying to connect HP a6230n pavillion to Sony Bravia HD TV
Using the original remote for the TV open the setup menu and select SVGA connection for IMPUT every time you use the tv as monitor i hope this solve the problem.
Posted on Sep 20, 2009
How do i connect my hp2560p to tv
You can use a VGA cable to connect from your laptop to your TV.
10FT 15 PIN BLUE SVGA VGA ADAPTER Monitor Male To Male Cable CORD FOR PC TV
Just make sure you have a connector on your TV....If you only have RCA inputs, you can buy an adapter. just plug it into your laptop and run the Red, White and Yellow to your TV with RCA cables.
VGA SVGA to Video 3 RCA AV TV Out Cable Adapter Converter PC Computer...
Thanks Hope this helps!
Please rate
Gary
Mar 17, 2014 | HP Elitebook 2560p Notebook 12.5" 2.5gI5...
Hooking dvr up to tv with a 15pin svga tv says change source resolution?
I have several DVRs, and have had similiar problems. I would first plug the DVR into a monitor and make sure it works. If so, then while you can see the menu, change the resolution.
Oct 27, 2017 | Philips Lm181e06 Lcd Panel Grade A Lg Dell...
Got a svga/hdmi cord and hooked up for my panasonic viera plasma to my computer but nothing shows on my component 2. also wondering if i'll need a cord for audio - i have double red/white/yellow...
You probably would need the extra audio cords seeings as normal svga connection won't suppost sound streaming. mixing and matching connections is always a pain to perfect.
If you are using the HDMI end on your plasma, then you will have the video show up on the HDMI channel. Then get an RCA red and white pair - 3.5mm jack and plug the jack into your PC's audio connection port and the RCA's into the Audio In ports in the back of the TV.
Once done the TV should display video and play sound from the PC. Failing this, try a few different configuration but always keep the audio plugged into the same Audio in port on the TV. Bacause then you at least know the channel that the audio works on ;D
Hope this helps mate, any more q's just ask!
Nov 23, 2010 | Panasonic Viera TH-50PX80U Plasma TV
How to connect a pc to an Insignia tv NS-L22x-10A
you can do this with dvi to svga or sv or get a monitor to component cord or dvi to hdmi, i do this with 3 of my tv's, call me if u like 3363926682 if this helps please give my the max thumbs up
Apr 16, 2010 | Insignia NS-L22X-10A 22 in. HD-Ready TV
Proper audio cable to hook up PC (headphone jack) to 50 in plasma
Hi there..
you just need a 3.5mm standard audio cable, from the green audio port out the back of the computer to the audio in port in the TV :)
can get them from ebay for 99p :)
hope this helps
alex
Apr 06, 2009 | Samsung PN50A550 50 in. Plasma TV
Trying to connect HP a6230n pavillion to Sony Bravia HD TV
Mar 21, 2009 | HP Computers & Internet
Does the dell dimension 2400 has an output to connect the to tv
You will either need a new video card with a compisite (yellow connector) or a s-video connector (looks like the end of a mouse), or somthing called a scan converter. Either of these products will allow you to use your telivison as a monitor for your computer. The last option is to get a telivision with a monitor connection on it. They are called SVGA connectors. If you go this way, you will need a Male to Male SVGA cable. Good Luck!
Jan 29, 2009 | Dell Dimension 2400 PC Desktop
Laptop connect to t.v. monitor problem
Did you verify the input on your tv?
There should be a source button on the side or bottom of your tv.
Click it until you see the VGA input.
I hope this helps you!
Sep 24, 2017 | Acer LCD 12 1 DSTN/SVGA Monitor
Liquid Video Monitor
Ebay sells them do a search for monitor cables. Good Luck I get them all the time
Mar 07, 2008 | Computers & Internet
Dual or mirror monitors
Their is a button located on the 1-9 keys, it looks like a little monitor. Maybe 2 monitors.
Hold down your FN key (Function) and press that button, that will turn on the svga connector. Also if you press it again it should keep both monitors on, and again will switch back to only the LCD.
Oct 11, 2007 | Samsung V25 XVC 2800 Notebook
Computers & Internet Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
