Question about 2wire 2700HG-B Router (2700HGB)
Dsl light is red and unable to connect to the internet
  • 68 Answers
Please ask your ISP to run the line test on your line.
The DSL line is not working but your phone line will work. There is a problem with your DSL signals.
Posted on May 03, 2010
3 Suggested Answers
SOURCE: Westell 327 wireless router
I found a solution for this problem. After complaining to Verizon Tech support, I finally got someone to listen. I talked to a Tech that I think was in India, nice lady that walked me through all the line test and finally a modem test. My connection keep dropping through the modem test, which I had a feeling the real problem was. I was told the modem was out of warranty and would cost $59.00 to replace at first, but after calling in so many times this lady sent me a new modem, not a 327W, a 7500. Disconnected the old modem, installed the new one and so far no more dropped connection problem.
Posted on Aug 01, 2008
SOURCE: Verizon DSL Internet connection intermittant Westell 327
verizon dsl westell 7500 internet light goes off 2 to 3 times daily
Posted on Aug 01, 2009
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
A problem has occurred when trying to access the internet. Please check your DSL/Cable connection and verify your internet connection settings. Wtf is this ? Firmware update doesnt helped. .
Cables connection might loosen up. Check cables that runs from the wall jack going into your modem, make sure all cables are tightly plugged in. Also, check indicator light on your device. If DSL light is RED, OFF, flashing red, flashing green. there might be trouble with your Internet provider. DSL light indicator MUST be always on STEADY GREEN. If you see that the DSL light is not on STEADY GREEN status call your Internet service provider.
Oct 27, 2012 | D-Link Dlink Dir-600 Wireless Router...
Unable to connect to the internet
possible reasons why you can't connect to the internet
1. Ethernet cable is not plug in tight from the modem to your laptop. 2. DSL light on your modem is RED/flashing green/ OFF 3. if you have router try to unplug both modem and router for 20 seconds then turn your modem on first and wait for the DSL light on the modem become solid green before powering the router ON 4. check the LACAL AREA CONNECTION. it might be disabled. to check click satart menu then go to control panel then look for network ana internet then click network and sharing center. From the left had side of the page look for manage network connection and click it then check if the LAN is disabled. if its disabled right click the LAN and select enable. 5. check internet connection again if it works
Sep 10, 2011 | Computers & Internet
The internet is down the dsl light on the modem is blinking red
I experienced the same problem yesterday with my modem,the internet is down as a result of the fact that the computer doesn't recognize the remote modem,hence the dsl light blinks red,when the internet is up the dsl lights should blink green,the problem is mostly from your internet provider,few times from your computer.
The solution is so simple;
1.Remove the modem from your computer.
2.Shut down your computer.
3.Turn on your computer again after at least 3mins.
4.Insert the modem in your computer and connect to the internet.
5.It might take up to a few attempts before it gets connected to the internet.
Problem solved.
Dec 02, 2010 | AT&T Computers & Internet
I have had problems connecting to internet all weekend (internet - red light), am on now but internet and ethernet green light keep blinking, is this ok.
No because dsl light should be solid green light. You need to contact your ISP to check if there is a problem on the network.
Jul 11, 2010 | Computers & Internet
Dsl light is red
if the dsl light is red, it means there is no signal coming thru your internet connection. so you need to contact AT&T to check your Dsl line signal
Jun 25, 2010 | 2wire 2700HG-B Router (2700HGB)
My Motorola Modem Mstatea
When the DSL light turns red it indicates that the modem has no internet signal.
So please check if the cables are connected properly
Also ensure that there is a proper signal to your premises without any interference
This is called intermittent connection
If the DSL light turns red it indicates that there is a problem with the cables connected or the DSL line
Please check your DSL connection with ISP
There is on another reason that the modem might have gone bad.
If all the above steps are executed and if this issue still persists replace the modem
Jan 28, 2010 | AT&T High Speed DSL Modem
Jul 11, 2009 | Westell Wirespeed VersaLink...
Dsl light flashes red constantly
Whenever your dsl light on the 2wire modem turns red,it only means that there is a problem with the dsl connection to the modem. Here are some ways on how you can isolate the problem
1. check if your modem is properly connected to the phone jack by unplugging and replugging you phone cable
2. try to reboot the modem
3. if still getting the same lights, contact your ISP
Nov 13, 2008 | 2wire HomePortal 1000HW DSL Modem and...
No Internet light on DSL modem
Try testing the line that goes to your dsl modem with a external phone.
If the internet light in your modem is not ON or RED that means that you have a problem on your phone line.
Nov 07, 2008 | Westell Wirespeed VersaLink...
2wire 2700HG-B Router (2700HGB) Logo
255 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
