Question about Fujitsu Stylistic 3500 Tablet PC
Is it sensitive to pressure?
The stylus and screen is it sensitive to pressure?
to use it like a digital tablet it will make a slight line when I press softly and a broad line when I make more pressure on the pen?
thankyou
I have a apex digital 7" internet tablet screen is slightly cracked and locked how do I unlock the screen
Put into a Ziplock bag and put it in the freezer for 48 hours. After you take it out press the On button every 5 minutes until it boots up.
Jan 03, 2015 | Tablets & eReaders
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Screen display on iPad 2 changed to blue background with slight flickering. This happened while using - it did not drop. Reset has not solved problem.
Turn it over on your lap or on something soft like couch or carpet. Karate it chop it on the apple logo. Start softly and keep using more force. Folks have even used a hammer to do this but I don't advise it. You can also drop it face down on carpeted floor. Your ipad is likely stunned and needs to be stunned again to return to normal.
Mar 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My soft-tip stylus does not always regester so I have to press it harder than before but when I use my finger the response is almost instantanious. I have a Kobo Arc, but not sure what gen it is. Does...
The unit adjusts to surface pressure. The XYZ points rely and the proper adjusted pressure and if the surface layer is damaged in any way, the pressure commands will not send the desired signals. Other than that, the stylus is no longer capable of changing axsis point.
Feb 26, 2014 | Kobo Arc
Where is stylus
Here is what you do. 1 call the company demand a refund or the stylus. 2nd resort buy a new stylus froma store.
Jun 28, 2012 | Coby Kyros 716829701508 Tablet PC
I have toshiba tecra m2 when i had install the graphics card driver and restart my laptop the lcd screen disappears (blackens) while the whole system keeps runnig and i am using the correct drivers...
hi friend
Press F8 Just after you press the power button.
a window will open select safe-mode use the arrow keys to select and hit enter .then safely restore the computer using system restore.or uninstall the graphics Driver from control panel.the drivers that you were going to install was digitally signed?
this thing usually happens when you install an unsigned driver . click her to know hot to use system restore
please rate me
Mar 05, 2010 | Toshiba 25 PACK DIGITAL STYLUS PEN FOR...
Pin does not work when touched to screen.
The stylus has a AAAA (yes, QUAD-A) battery in the body of the stylus - if this is dead, then the digitizer won't recognize the pen. That sounds like what is happening - the batteries can be found at bigger Radio Shacks or ordered online.
Oct 22, 2009 | Motion Computing LE1600 Tablet PC
I need to change the tip of the stylus
I own a Toshiba Tablet PC that uses a wacom stylus.
With the stylus replacement tips there is an extraction tool: It looks like a wide ring split lengthwise.
You take the tool between thumb and index ( as you do a tweezer) and extract the worn out tip.
Toshiba warns against letting the tip wear out too much: this renders extraction difficult.
Once you have extracted the worn out tip, insert a new one with the thinner side towards the outside.
Press gently but firmly to make sure it is holding.
Hope it helps.
Aug 17, 2009 | Toshiba 25 PACK DIGITAL STYLUS PEN FOR...
Problem with the touch screen an stylus
Press the Up + Down buttons at the same time. This will turn off the "Digitizer" function on the tablet and allow the user to use their finger, the stylus, or blunt end of a pen.
Aug 21, 2008 | Itronix Duo-Touch Tablet PC
Fujitsu Stylistic 3500 Tablet PC Logo
57 people viewed this question
Top Fujitsu Tablets & eReaders Experts
Tony
Computer Links
Michael Vincent Cruz
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
