Question about Denon AVR-1907 Receiver
I have a denon 1907 reciever, which has no hdmi hookup. I bought a blueray with hdmi. My tv has hdmi. can i some how use hdmi for the tv and cables for the receiver
  • 416 Answers
You should have an optical audio out on your tv and optical in on your reciever
adjust the settings on the tv appropriatley and you should be good to go.
GOOD LUCK AND PLS RATE THIS POST!!!!
Posted on May 03, 2010
How to connect a denon avr-e400 receiver to a televion
If the DENON has an HDMI output, and your TV has an HDMI input, then use a HDMI cable. Then, use the TV's remote-control to select "source" (or "input") as 'HDMI 2' or 'HDMI 3' (assuming that you have been using 'HDMI 1' to watch TV).
Feb 08, 2015 | Denon AVR-E400 7.1 Channel 4K and 3D Pass...
How do I get HDMI cables to sync or talk to each other. We had this problem when we hooked up an Apple TV box to a Denon AVR-E400 and our Sony HD TV. We were told to disconnect all HDMI cables unplug
Personally I would use an RCA cable and hook up the AVR.
((RCA out of TV to AVR audio in))
((cable box HDMI cable output to TV HDMI Input1))
(As far as the AppleTv I would use a separate HDMI Input2)
If your AVR has a dvd or blue ray player Hook up a
HDMI cable out to another Input HDMI3 of the TV
using separate inputs on the tv will allow your surround system to be
used on all modes(CABLE,DVD/BLUERAY,APPLETV)
Sep 27, 2014 | Denon AVR-E400
Hi with my denon avr 1908 can i run video through HDMI cable and sound trough Coaxial cable so i can get 5.1 surround from my sky HD box
you can get 5.1 using HDMI connection.
other wise in the set up you can configure the denon to not use the hdmi audio and configure that input to use coaxial or optical all digital inputs allow for 5.1 once all connections are made on the front of the unit find the input mode button and select auto
Jun 30, 2009 | Denon AVR-1907 Receiver
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Speaker interference
you should be able to disconnect the analog audio cables from the cable box and Denon, with the HDMI connected, press the input mode button on the front left of the reciever to select auto and that should fix the issue
Feb 01, 2009 | Denon AVR588 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
I have a new Denon 688 7.1 CH reciever. I did a sound test on all speakers and they all worked. I hooked up Satelite rec HDMI and PS3 HDMI to reciever and then an HDMI from reciever to TV. I have Picture...
The Denon 688 does not process sound via HDMI, you have to run a seperate cable to get sound. Choices are analog audio jacks (red and white) or either a toslink (optical) cable or an rca digital audio cable.
Cheers!
Mar 15, 2008 | Audio Players & Recorders
Denon AVR-1907 Receiver Logo
299 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
