Apple iPod nano Logo
Posted on Mar 25, 2008
Only one earphone works
Right earphone works only only the right side of the earphones work on the iPod nano. But in other electronics, both sides of the earphones work.
  • Kurt Van Etten
    Kurt Van Etten Mar 26, 2008
    How to I check to see of the programming is correct?
  • Anonymous Oct 28, 2008
    i have exactly the same but my left ear only works... what shall i do?
A
Anonymous
I have same problem
i dont know
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Mar 26, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
Helped
1991
Points
19
That means that the programing of your ipod is only on head phone or you did not insert the wire in correctly
1helpful
2answers
I plugged my earphones into my ipod and laptop to play music, and the music comes out of my left earphone, but not the right
This could the way the music is been recorded if it is strero or mono, also do confirm the earphone if one side of the earphone is faulty or not, if bad replace with the exact type and if not the media itself is faulty, you can take it the an electronics repair shop for them to diagonised the appliances... Hope this will help in solving.......
The earphone jack connection produces sound in only one ear. Partially with drawing the jack produces sound in both ears. Clearly, the jack is not making a good connection once inside its 'port'.
This is usually the result of faulty earphones. Try replacing the earphones you are using with the ipod and it should work normally.
Good Luck!
1helpful
2answers
The internal speaker for my ipod nano will NOT turn off
The speaker on my new Ipod nano the one with the camera won't turn off when i plug the headphone in it. Help please :(
9helpful
How do I adjust the volume on my iPod Nano with earphones?
Plug the headfones all the way in, force them in. it works, i had the same problem.
Ipod nano 2GB
have you tried different earphones?
Ipod nano 2ndG one headphone out
Sometimes if the plug of earphones are inserted half way, only one of the earphones play. Please try to remove and insert again and see to that it is fitted in properly and completely.
Cheers.
IPOD IS NOT WORKING
cuase youre earphones are lost.
Cant hear out of one side of earpiece
have you tried using differnt earphones? if the problem is still the same with different earphones then it's the ipod itself that has a problem, you'll have to get it fixed.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
