Question about Lanzar VIBE286 Car Audio Amplifier
Have a lanzar vibe286 and when turn on it blows one fuse why
    President:
  • 196 Answers
Bad output transistor or fet transistor.
Posted on May 06, 2010
I have the same amp and experiencedthe same problem. Before thinking that the internals are bad check your speaker wires to make sure they are correct and not crossed anywhere. I had my speakers wired wrong which is what caused this problem for me. Also be sure that your grounding is solid.
Posted on Apr 27, 2011
Lamar vibe286 car audio amplifier has a blown compacitor
if a cap has blown then the mos-fet's has probably gone down and to be honest there will be a lot of other possibility, how did it happen?
Apr 11, 2012 | Lanzar VIBE286 Car Audio Amplifier
How do i reset my 4000 watt lanzar vibe 286 from being in protect mode
You can only reset it by disconnecting power to it. If it is in protect you may want to check your speakers and speaker wires for shorts and/or grounds. If they check out all right you may have internal problems in the amp.
Oct 28, 2011 | Lanzar VIBE286 Car Audio Amplifier
My subwoofers cut out after 30 seconds of use but work fine during the 30 seconds...my fuses are all fine and i'm running thick wire with an 80 amp fuse connected off battery...I have a lanzar vibe286...
If it's only your subwoofers cutting out and your speakers are still playing and all, try turning gain down on sub amp and see if that fixes it. I know if I crank my amp too high it kicks itself off to try to keep itself from blowing.
Aug 21, 2011 | Car Audio & Video
Hits hard with one sub but has no bass with 2
do you no what ohm your amp can do and what your subs are
Oct 07, 2009 | Lanzar VIBE286 Car Audio Amplifier
I have a lanzar vibe 286 its a very good anp and kick hard but it gets very very hot so hot you can **** an eeg on it what shud i doi know i can install a fan on it but were the back or front i dont know...
The impedence of the speakers does not match the amp operating impedence. This amplifier is made to run a 2ohms stereo stable which means 2ohms per channel or 4ohms bridged.
Jun 25, 2009 | Lanzar VIBE286 Car Audio Amplifier
Lanzar vibe 286 speakers pop when it is on
Turn Down the Gain a little bit at Medium Vol. Till they don't Pop. Go to www.Crutchfield.com for a Wiring Diagram.
Jan 04, 2009 | Lanzar VIBE286 Car Audio Amplifier
No power
You probably have ONE of the speakers wired out of phase.
If the speakers are wired correctly, you may have the crossover set to high pass instead of low pass.
Let me know if you have any other questions.
Aug 11, 2008 | Lanzar VIBE286 Car Audio Amplifier
Fuses
Hi, when the fuses blow it can only mean that the current the passed thru it is greater than its rating. It is possible that the fuses installed has a lower rating than is required by your amp. To check look over the specs of your amp and determine the proper amperage (amp) rating. Specs may be found on a sticker at the bottom or side of the amp and may look something like 12V-20A meaning 12 volts 20 amperes. In the absence, you may want to check the box and/or the instructional manual that came with it ot go to the manufacturer's website to checkout the specs. If you are referring to the fuse serving all your amps, players, receivers, etc, then you have to addup all their individual A rating and get a fuse whose rating is equal to the addedup value. Although this is not a sound practice and individual fusing is preferable. If the amp rating is equal to the fuse rating but it still blows, then you may want to have your amp checked. Trying to install a higher rating will most likely prevent fuses blowing and present itself as a temporary solution but the real problem is not solved and may be aggravated. Hope this be of some help and good luck.
Apr 22, 2007 | Lanzar VIBE286 Car Audio Amplifier
Lanzar VIBE286 Car Audio Amplifier Logo
173 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
