Question about GE WBSE3120B Top Load Washer
Wont spin and ring clothes out their still wet
  • GE Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on May 03, 2010
  • 250 Answers
SOURCE: spin cycle leaves clothes very wet
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Feb 09, 2009
  • 7 Answers
SOURCE: MY ADMIRAL WASHER WONT SPIN FAST ENOUGH..IT DOES SPIN BUT WHEN IT STOPS THE CLOTHES ARE STILL DRIPPING WET
Sounds like a whirlpool or inglis type belt drive with a loose belt or bad basketdrive[clutch].
Could be the set screw backed out on the basket, thats a pretty common problem.
I'd need a model number to know who made it though.
Posted on May 19, 2009
  • 10865 Answers
SOURCE: clothes are sill soaking wet after sin cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Posted on Aug 18, 2009
emissionwiz
  • 76164 Answers
SOURCE: clothes wet after rinse cycle
lift the washer on its side and see if it has a drive blet that broken for the spin cycle.
Posted on Sep 16, 2009
  • 403 Answers
SOURCE: kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Posted on Oct 05, 2009
Why are clothes dripping wet after final spin?
There is a balance sensor in the machine that checks to see if the load is distributed for high speed, When that sensor goes bad, the machine wont spin the water out of the clothes. YOu need to check for spares
Apr 22, 2016 | Tricity Bendix AW1000W Front Load Washer
Clothes come out of washer wet
Most often you have a worn out belt that spins the drum when it is time to spin dry. Upend the machine and check the belt, if it has one.
A new drive belt should fix you right up.
Mar 14, 2016 | Washing Machines
My maytag atlantis cycles but wont spin out. It spins slowly then shuts off but leaves wet clothes and water in tub.
First determine whether all the water is pumping out before it goes into spin. If not, check the pump and drain. If its not spinning fast enough with an empty tub check that there isnt any article of clothing caught between the inner and outer tubs or tub top ring. If thats ok check the clutch by turning the main drive pulley CCW. Substantial drag should be felt before the basket overcomes momentum and begins to turn. There is no repair for the clutch on this machine. The transmission must be replaced.
Jul 14, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore washer 3.5 super capacity. Machine spins
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Need help please with washer machine,wont spin my cloths,just drn
a belt has snapped or came off or the motor and brushes are damaged.
Sep 20, 2009 | Maytag MTW5700TQ Top Load Washer
Washer wont spin clothes are still wet
The lid switch is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Kenmore Washing Machines
Washing machine spin problem!!!!!
whirlpool estate washer is dun the clothes are ring Wet
Jan 13, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Frigidaire front load washing machine gtlf490e
just change the door switch been there done that have the t shirt
Sep 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Neptune washer
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
GE WBSE3120B Top Load Washer Logo
111 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
