Question about Kenmore 44102 Front Load Washer
Front load washer not draining
(problem started today) our washing buzzes to indicate it's done with it's wash, but when we go to pull the clothes out, everything is soaked and water has not drained...help please?!?...
  • kingcrab May 02, 2008
    I can hear the clicking sound, seems like it's trying to drain, but then immediately it will go to the next cycle. In essence the water is never drained. it will sound the buzz at the end of the wash program, leaving all the water in the washer. Seems like a timer, computer chip problem
My kenmore front load was just gurgling and flashing F01.It was a baby sock stuck in the pump. It has three 1\4 " screws. The pump is a white unit to your right and it has a big round cover that can be unscrewed easily.
Posted on Jul 14, 2008
2 screws front panel I can't remove then odd type screw !!!
Posted on May 03, 2008
    Problem Solver:
  • 10 Answers
If the water is not draining the firt thing to check is the pump. take the 2 screws off the front bottom panel and remove it. get a bunch of towels or a wet dry vac ready. the pump should be on the right attatched to the drain hose and the coin/debris cather(a black rubber bladder. Remove the drain hose (use pliers on the clamp and pull the hose off. A lot of water will come out as well. Remove the rubber bladder(coin catcher) clamp with a philips head screw driver and pull it off the pump.Un plug the pump remove the monting screws. Check the pump and the bladder for debris. Look in the pump and make sure the impeller is not damaged. spin the impeller and make sure it moves. if the impeller is damaged then the pump need to be replaced. Assuming everything seems ok reassemble and run an empty load with the dial set just before final spin. If the pump is working you should hear it, and possible feel water moving through the discharge hose.
Can you tell me what nf means
No fill error. The washer thinks it's taking too long to fill up with water
Dec 14, 2014 | Kenmore Elite 45986 Front Load Washer
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Clothes are still soaked when cycle is done
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 15, 2011 | Maytag Neptune Washer
Washer is Full of water and clothes but won't drain. The washer will not start in any cycle. Lights are on ( the start light is blinking). Tried unplugging but still will not start.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
New calypso today. when the clothes are done the are soaking wet
heatman101
Sep 03, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer goes through wash cycle but will not drain, spin and buzzs. Time remaining shows in display. Unplugged and plugged back in again and buzzing continue and time still shows in display. Help!
heatman101
Sep 01, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Clothes as still wet when it is finish after washing is done
Hello Sassylips,
Clothes will always be wet after a wash but if you are saying that they are soaking wet rather than just damp from a frontloadre like yours then you may have an obstruction in the pump system.. That could be anything from a screen preceding the pump, some obstruction in the pump itself, a pinched or clogged drain line exitting the washer or restrictive flow in your home drain system. A simple check that can be done would be to take the drain line out of the house drain and put it in a barrel. Watch the flow of water when the washer cycles thru a standard wash and see if it appears to be a reasonable level. A trickle would indicate one of the problems I mentioned previously. Have you ever cleaned the drain screen? Those are a few potential issues that could cause your clothes to remain wetter than they should be after a wash cycle. Also, you might try washing a few articles of clothing and then check to see if they are as wet as larger loads when the cycle is complete... Hope these ideas help you identify the cause and are able to resolve your problem...
Regards
Nov 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Can''t get my clothes out... water still inside
does it have a dial that you can manually turn to start the next cycle? You can usually drain the water by pulling the drain hose out from the wall drain behind hte washer....( usually just shoved in the drain not attached) but be aware that when you hold the hose below the water level in your washer it will start to drain. Then perhaps the door will unlatch.
Sep 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool washing machine will not start indicator lights on press start button clicks once and nothing happens
opened bottom panel of washing machine unscrewed filter drained out water found cloth item in pump area cleaned out ok for a while problem reoccured repeated process more cloth found problem resolved.
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer flashes a 02 error during the final spin/drain cycle.
f02 is a fault indicating poor drainage, try removing hte front access panel and cleaning out the pump housing!
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 44102 Front Load Washer Logo
97 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
