Question about Nikon Coolpix S51c Digital Camera
My camera won't turn on. I just recharged my battery and reinserted it and now the shutter won't opn.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 03, 2010
Finepix s602s
How to turn on a Finepix s602s camera:
  • Hold the camera with the back of the camera toward you.
  • Find the shutter button on the top of the camera on the right side.
  • You want to rotate the ring around the shutter button using the little lever just in front of the shutter button. The first setting will put the camera in video capture mode, and the next setting will put it in photo capture mode.
  • If the camera won't turn on, try new batteries. It uses regular AA or rechargeable AA batteries.
I hope that helps you!
Jun 21, 2014 | Cameras
Won't stay on
i could be that the rechargeable batter is weak. try replaceing the battery for a new one. also check that the connections for the battery are clearn.
I hope this was useful.
Feb 15, 2013 | Sony Cyber-Shot DSC-P52 Digital Camera
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
Hi, The shutter on my sony dsc - p73 will not open all of a sudden is there any hope of being able to sort this?
I'm sorry that the shutter of the sony dsc - p73 will not open. I suggest that you perform a power reset and check the operation.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera
If the issue is not resolved, service will be requred.
Dec 13, 2010 | Sony CYBERSHOT DSCP100 Digital Camera...
Sir, Shutter of my Digital camera Sony Cyber-shot DSC-P72 is not closing / return to original position completely. I have tried with changing the battery too. Every time that I do power on the massage...
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C91134&fes=true&mdl=DSCP72
Try doing a power reset:
Solution
sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
  7. Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Region
sp.gif sp.gif Canada Latin America United States Products
sp.gif sp.gif Cybershot Digital Still Camera Last Modified Date: 03-04-2010sp.gifID: C265373
Jul 23, 2010 | Sony Cyber-Shot DSC-P72 Digital Camera
Shutter stuck
I wonder how good your rechargeable batteries are-even these lose their ability to recharge fully after a while. Try some non rechargeable good quality batteries in it and see if it then works properly.
Jun 18, 2009 | Canon PowerShot S2 IS Digital Camera
Nikon coolpix s1
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 18, 2008 | Nikon Coolpix S1 Digital Camera
Sony cybershot dsc-s90
Hey Gregorious03,
You could try removing the batteries for at least one minute and then reinserting them, or you could try initializing the camera back to the factory settings under the setup menu. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 14, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Nikon Coolpix S51c Digital Camera Logo
93 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
