Question about Konica Minolta bizhub C250 All-In-One Laser Printer
My konika copier error code c9401. How to clear code.
    President:
  • 524 Answers
Try this steps
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
1 Check the flat cable for proper connection and
correct or change as necessary.
2 Change PWB-C.
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 03, 2010
    New Friend:
Comment ?viter le code c9401 avec konica minolta c250
Posted on Nov 14, 2015
How to remove error code M2
question too vague.
make? model?
example:
Re: Konika Minolta BizHub 163 - Error Code? M2
• To display the count of the supplies life counter.
When the counter reaches "0", life 1 will be detected and maintenance call M2 will appear.
The initial value is 40,000, and the countdown system is used.
Use Setting/Procedure
• To clear the count, use [CLEAR DATA] of the Service Mode.
Jun 06, 2015 | Office Equipment & Supplies
Error code c9401 konica minolta bizhub 36
Scanner lamp assembly, that is the bright light that come on the document feeder, there is a problem with it. Need to be replaced. or the control board needs to be replaced. No reset
Sep 06, 2014 | Konica Minolta Office Equipment & Supplies
I have a C9401 trouble code on bizhub c550 how can i remove the code?
if this procedure does not clear and it come back mite need new exposure lamp or CCD exposure lamp is bright lamp under the glass the CCD is the large black device under the big class to your right.
Power off the with the main switch. now ensure sub power switch is on the power switch on the control panel, now hold down utility /counter button and turn main power on SEE a TROUBLE RESET touch it goes to Ok. power the machine off wait ten second. and power on normally. if it come back do not reset until parts are replaced the machine is telling you I am broke you keep resetting it can get worse $$$$$$$$$$$$$$$$$$$$$$$
Jun 13, 2014 | Konica Minolta bizhub Office Equipment &...
How to solve M2 in bizhub 164
Konika Minolta BizHub 163 - Error Code M2
Press the Utility button,
then Stop 0 0
then press again Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Feb 23, 2014 | Minolta bizhub 200 All-In-One Printer
How to reset error c3451 in konika minolta 215
clear/stop held down and turn the machine on, IF THIS CODE COMES BACK DO NOT RESET AGAIN IT IS POINTING TO FUSER UNIT IT CAN CATCH ON FIRE GET TECH OUT AND REPLACE THE FUSER
Feb 14, 2014 | Konica Minolta bizhub 200 Printer
How can i reset m2 bizhub 211
I Have a Konika Minolta bizhub 211. I had been trying this solution for repairing m2 call. but the code is appear till now. anyone help me. please give me solution step by step.
Thanks
Mar 05, 2011 | Sharp AR-5320 Black and White Copier
Our machine shows C9401 default, can you help us in solving this problem
Not exactly sure if the model is the same but on a C351 the C9401 & C9402 errors are as follows:
16.6.81 C9401 Exposure lamp failure to turn on
16.6.82 C9402 Exposure lamp turning on at abnormal timing
Parts to check:
Scanner Assembly
Flat Cable
Image Processing Board (PWB-C)
Step Action
Corrective steps in order of suggestion:
Check flat cable for proper connection and correct or change as necessary.
Change Scanner Assembly if necessary
Change PWB
Apr 29, 2010 | Konica Minolta bizhub C450P Laser Printer
Konica bizhub C351 with a C9401 error code
adjustment.
Change PWB-C.
Aug 03, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
1,319 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
