Question about Jabra Bluetooth Headset with Adjustable Ear-Hook Headset
I have a Jabra BT2070
How do I connect my bluetooth to hear music through my cell phone
Kidyubyub
  • 143 Answers
SOURCE: How to hook up a Jabra BT350 bluetooth
Make sure your cell phone's bluetooth is activated. Once you do that, you should be able to hold down the main button on the Jabra and once it turns on, it will connect with your phone.
Also, go to this site for Jabra. It links directly to the manual.
Posted on Jun 22, 2008
SOURCE: cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
Posted on Dec 08, 2008
SOURCE: LG enV2 cannot locate my Bluetooth device Jabra SP5050
Followed step by step of pairing instruction of Jabra SP 5050 manual on the Web.
Thanks
Posted on May 18, 2009
  • 13 Answers
SOURCE: jabra BT350 bluetooth
While the headsetis off, press and hold the power button for 6 seconds. It will first blick the light in several patterns, all in blue. Finally, it will come on solid blue, no blinking. It is now ready to be paired. Once your phone/PDA has detected it, the passkey /should/ be 0000, as in zero zero zero zero. That should do it. Best of luck! :-D
Posted on Jul 15, 2009
homedesigner
  • 583 Answers
SOURCE: I cannot get my Blackberry Storm to pair with my Jabra BT2070.
You have to first put the Headset into discoverable mode. According to the Jabra website, this is done by pressing and holding the end/mute button until the light comes on steady. Follow the procedure for your phone to pair a bluetooth device to it. The PIN code will be 0000.
Posted on Feb 07, 2010
I cant use my jabra BT2070 what is the password for pairing update????
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
Apr 30, 2011 | Jabra Bluetooth Headset - BT2070
How can i connect my jabra bt2070 with my computer running windows 7?
You can buy a bluetooth usb adapter and make your pc bluetooth enabled. I bought an I/o gear blue tooth adapter for $ 2.58 and it allows me to pair up my headset to my pc and I can go up to 500 ft away and hear perfectly.
All you need are 2.0 usb ports (high speed)
the adapter can cost up to $ 20 but it works and boy is it worth it!
Apr 20, 2011 | Jabra Bluetooth Headset - BT2070
Can I connect my garmin nuvi 1310T to my Jabra BT2070 bluetooth headset earpiece
You probably cannot. Some bluetooth devices act like phones, and others act like earpieces. The Garmin acts like an earpiece to offer a hands-free speakerphone while driving. Your Jabra earpiece wants to pair with a phone, not other earpiece-type device.
Apr 18, 2011 | Garmin GPS
I am pretty sure that the numeric passkey for Jabra BT2070 is 0000 but it doesnot work in my blackberry 8900. how do i connect it to my phone ?
Try this... 1. Turn off the Jabra bluetooth. 2. Turn on by pressing Volume up + power button until the power light comes on steady. 3. Then turn bluetooth from your blackberry 8900 and make the bluetooth seen/available by other devices. 4. Search bluetooth in range...Look for Jabra BT2070 click then will ask you to put the code which is "0000" or "1234". 5. Then check if the steady light comes to blink...
Mar 19, 2011 | Cell Phones
Someone change my passkey of jabra bt2070 how i get it
hello first i would like to know if your phone is paired with ur bt device if it is and it is asking for your pin code again most pin codes for manufactures are as follows 0000,9999,1111,or 1234.hope this is the answer you are looking for..now if your device is not connected you need to reconnect the device to your phone ,follow your cell manufactures procedures for connecting your bt device and make sure u set your bt device to discovery mode,then when it asks for the pin code enter one from above most are 0000 but the odd time one of the other codes is required...hope this helps
Feb 22, 2011 | Jabra Bluetooth Headset - BT2070
What if i can't find my model phone for instruction to connect to?
Hi
Paring the JABRA head set to Mobile phone
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT2070.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 (4 zeros)
Thank You
Aug 31, 2010 | British Telecom Jabra BT8040 Wireless...
I have a jabra ote3 bluetooth. i don't have the manual. can i connect the bluetooth to a verizon motorola razor?
Yes,You can connect the Jabra head set to motorola razor.
Please follow the steps to connect it to motorola razor
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 .
Thank You
Aug 11, 2010 | Cell Phones
Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Logo
83 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
