Question about Cell Phones
Hi, I need to know how to delink or unregister one of the 3 handsets from my panasonic KX-TG9333T cordless phone and register it to another panasonic KX-TG9331T cordless phone. Marc
  • crampra May 04, 2010
    Yes the solution was helpful. The instructions to de-register and register an existing unit was provided in the instruction manual. I should have read the instructions first.
    Anyways thanks for the help and i achieved what i wanted to do.
  • Cell Phones Master
  • 12,061 Answers
Http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/model.KX-TG9331T
http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
Above are your user and service manuals, everything to do with any feature of your phones are in them.. download and have a look through, the manuals, I am sure you will sort out your problem.
Posted on May 03, 2010
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
Where can I get an instruction manual?
Panasonic kx-tga600b handset manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tga600b cordless extension handset manual. Panasonic kx ...Panasonic kx tga520 5.8 ghz fhss cordless expansion handset manual. Panasonic kx ... Panasonic kx tg6071 operating instructions manual pdf download. Panasonic... Need manual for kx tga600b so i can turn off voice mail dont need. Panasonic ...
Kx-tg6500 manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tg6500 operating instructions manual pdf download. Panasonic ...Panasonic kx tga650b cordless extension handset installation. Troubleshooting ...Panasonic kxtga651b dect 6.0 plus expansion handset black kx. Panasonic kx ...Can i register a kxtg6500 handset with a kxtg4500 base. Panasonic kx tg6502 ...
Panasonic KX-TGA650B ' Installation Manual - Page 3
Feb 09, 2016 | Panasonic KX-TGA650B (037988474806)...
I cannot get my Panasonic base KX-TG5583 to register 8th handsets - only seven
It has to do with the electrical load that each ringer imposes on the line. Each set has a limit on how many handsets you can register with it. If you look on the bottom of the base you will see on the identification plate a data item called Ringer Equivalence Number or REN.
In telecommunication, a ringer equivalence number (REN) is a somewhat arbitrary number which denotes the electrical load a telephone ringer has on the line.
Dec 05, 2013 | Panasonic KX-TG5583 Trio Cordless Phone
I need to know how to unregister a handset from the base. Model kx-tga450b
On the base, press menu, initial setting, registration, deregistration. Then choose the handset number you wish to deregister.
May 09, 2011 | Panasonic KX-TGA450B Cordless Expansion...
I have a panasonic cordless phone, model kx-tga820. for some reason both handsets now say that it is busy when i push the talk button. Our other phones are ok. Why?
If you get busy tone in your Panasonic KX-TGA820 cordless phone, it may be due to any one of the following reasons:
1)The called handset is in use.
2)The handset you are calling is too far from the base unit.
Check whether the base unit is not so far from the handset
3)There is no handset registered to the base unit matching the extension number you entered.
Try to re-register the handset to the base unit again, To know details regarding registering and re-registering, please refer page 38 of the manual, which you can download from the link given below
4)Other units are in use and the system is busy. Try again later.
Try to check whether the other units are not using your base unit
You can download manual for your phone from the following link for reference
http://service.us.panasonic.com/OPERMANPDF/KXTG8231.PDF
Please rate this solution
Rnj VINODKUMAR
Nov 10, 2009 | Panasonic Lands Phones
A busy signal
Hi Kevin,
Sorry for being off line so long. If you have not fixed the problem already, I would try de-registering the handset 3 (from both the base and handset), then re-register it, it should re-register as HS 3, unless 1 and 2 are vacant. If that does not do it, de-register just the handset (not at the base), then re-register it to the base, it will grab the next sequencial intercom number. If it is still failing, then the handset is most likely defective. As a last resort, you can try initializing the handset and the base. Let me know how it goes. CG
Apr 03, 2008 | Panasonic KX TGA400B Cordless Expansion...
Got instruction to unregister KX-TG6074B
If this error message displays on your handset, please follow the instructions below to deregister your old handset before registering a new handset.
1) On the base unit:
Press: FUNCTION or PROGRAM
Button name varies by phone model.
2) Press: MUTE
3) Enter the numbers 3, 3, 5, #
4) Enter the handset number (1 to 8)
Mar 14, 2008 | Panasonic KX-TG2740 Cordless Phone
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Oct 18, 2007 | Panasonic KX-TG2740 Cordless Phone
Cell Phones Logo
204 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
