Question about Apple 20gb Ipod Mp3 Player With Click Wheel System
My ipod is showing a folder with and exclamation mark and folder, how do I repair it?
    Problem Solver:
  • 11 Answers
This can be various problems. It might be able to be fixed by simply opening up the ipod and re-inserting the logic board cable to the hard drive. This problem could also be fixed by restarting your ipod, putting it in disk mode, and restoring it with itunes. If this doesn't fix it, you need to replace your logic board or your hard drive.
Check out this link and this link for more information.
Posted on May 05, 2010
Hpdv9910us cd/dvd does not play
IF you go into my computer and your drive is not showing then i would go into your device manager and see if your cd/dvd drive shows a exclamation mark if it does then you have to go into your registry and delete upper and lower filters
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
if you show no exclamation mark in your devicemanager then you myst call HP for repair
Mar 01, 2011 | HP Pavilion DV9910US Notebook
My ipod mini 4gig has been corrupted. trying to restore but unfortunately it wont. it is just showing an apple icon and a triangle with a exclamation point. when connected to a computer it does not...
There are many iPod error icons with exclamation marks
The Sad iPod icon (93936_4.gif ) usually means that the iPod can't access it's Hard Drive. I've seen that hitting the ipod on a soft surface occasionally fixes this. You may need to take the iPod for repair
The Folder Error icon (93936_1.gif) may mean the battery is low, the ipod needs to be reset, restored or needs a service
The Battery Icon (93936_2.gif) usually means the battery needs charging
93936_3.gif means a disk scan failed and will be repeated when the ipod is turned on or reset.
Try restoring it continuouly until it does (eventually worked for mine)
if it is anything else, your iPod may need repair.
Good Luck!
-AC
Jan 02, 2011 | Apple iPod mini 2nd generation MP3 Player
Computer and ipod
The exclamation mark next to a title in iTunes means that iTunes cannot locate the song associated with that title (original file cannot be found). The cause for this is an incorrect setting of iTunes preferences when copying iPod songs.
Before copying your iPod songs, setup your iTunes preferences as follows
  • Open iTunes preferences (in the Edit menu)
  • Select the Advanced tab.
  • Make sure the box next to "Copy files to iTunes Music folder when adding to library" is checked.
  • Click OK.
Then use a program like TouchCopy to copy your iPod music to iTunes. You can download TouchCopy from here
http://www.wideanglesoftware.com/touchcopy/
Mar 13, 2010 | Apple iPod classic MP3 Player
MY IPOD IS SAYING GO TO WWW.APPLE.COM/SUPPORT/IPOD
If the iPod is showing the "Sad iPod face" icon, this means that the hard drive inside the iPod is dead and needs to be replaced.
If the iPod is showing the "Folder/Exclamation Point" icon, this means that the logic board (the circuit board) inside the iPod is no longer working properly and needs to be replaced in order for the iPod to work.
Feb 12, 2009 | Apple 20gb Ipod Mp3 Player With Click...
Iod scren displays a yeidl sign and folder file on the screen
Hi, As i understand you see a folder with exclamation mark on it...
So 1st you hav to try resting the ipod.... Try to press and hold the menu and the center button for approx 6 to 8 secs... then once you see a Apple logo release the buttons. this should work
Other solution would be restoring your ipod to factory settings by connecting it to computer and restoring it using itunes... then update the software as well
If not... try to connect the ipod to computer and then open Mycomputer....Right click on ipod.... then format it.... wait for the format process... then using itunes restore it to factory settings
This has to work
Reply if unable ot if you need any help
Feb 03, 2009 | Apple iPod nano
IPod won't turn on, apple sign comes on, then a file image with exclamation mark
Dear Rachel, This is often the result of a corrupt file system or a dead/dying internal iPod hard drive.  The way to eliminate the file system as the cause is to do a RESTORE.  It is probably not showing up on the computer in iTunes, so you need to try to force it into disk mode.  To do this, follow the instructions below: 1)  Toggle the HOLD slider switch to ON then OFF again.  First slide over you will see orange, then slide it back to cover the orange in the hold slider.
2)  Repeat what you did by holding down the menu and select buttons and when you get the Apple logo, IMMEDIATELY let go and hold down the Select and Play buttons.
3)  You SHOULD see a check mark on the screen and along the top of the screen should be the words, "Disk Mode."  If that is there, plug in your iPod to the computer and wait for iTunes to startup.
4)  In iTunes, select the iPod and then just click on the RESTORE YOUR IPOD button to reinstall the original software (you will lose your tunes stored in your iPod, but you should have them on your iTunes anyway).
If none of this works and you get the nasty sad icon again, it is most likely the hard drive or another hardware issue.  My advice from here is to check with the following company and have them do a FREE diagnosis and quote for repair.  Just go to Rapid Repair at this URL:  http://www.rapidrepair.com/
Good luck and I hope this helps! Jeffrey Wrobel
May 09, 2008 | Apple 20gb Ipod Mp3 Player With Click...
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
if that doesnt help contact apple or your dealer for more assistance or repairs.
If you need more asistance, let me know. Good luck.
Mar 12, 2008 | Apple iPod mini M9160LL/A MP3 Player
Ipod help
Feb 11, 2008 | Apple iPod 3rd generation MP3 Player
My iPod (4th gen 20gig) seems to have died... when you switch it on the apple logo appears then a folder with an exclamation mark... It also isn't recognized when you plug it into the PC...Also I have seen...
battery is not the problem, most likely your hard drive is bad, or motherboard is defective somehow, try open the ipod, and disconnect the battery, see if hard drive connector is installed properly, then plug the battery back and try to turn it on, helps 50/50, if not - replace the hard drive
Aug 23, 2007 | Apple iPod MP3 Player
Apple 20gb Ipod Mp3 Player With Click Wheel System Logo
177 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
