It fills but does not commence washing. LE comes up on the display as well a signal beep
  • 3 more comments
  • judyandstuar May 03, 2010
    Would like another opinion please
    The Washing is an NEC NW452, not an LG.
    My washing machine is an NEC NW452 top loader, but I keep getting replies about a front loader LG?
    Can you help me with my NEC?
    Please help me with this problem on an NEC NW452 washing machine, not an LG.
  • m_meacham
    m_meacham May 08, 2012
    Replacing the hall sensor AND turning the tub clockwise 4x and counter-clockwise 4x did it for our LG WM2032 (2004 model)---BEFORE I plugged it back in. I also had to rubber mallet the stator motor cover back on.
  • 12,061 Answers
Unplug it for about 20 minutes, rotated the drum three four times, and empty the water chamber from the tubes behind the bottom door. That should fix you up.
http://lizard43.blogspot.com/2009/12/lg-washer-le-error.html
If the above Fix doesn't work, it may be a hall Effect Sensor, in the above link, it shows you how and what to do. Good luck.
http://www.howtomendit.com/answers.php?id=28214
Above a useful reference link, many have same problem.
Posted on May 03, 2010
  • 5,081 Answers
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error, but it is possible to separate the working from the non-working, just by following a process. T
The Hall sensor failure is ver common. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
  • Washing Mach... Master
  • 43,501 Answers
The LE code can be a result of a number of things...
I have a detailed list of the possibilities in thew tip that I wrote about this code...
LG Washing Machine LE Error Code or Fault Code
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
  • 8,197 Answers
Solve LE error by replacing Hall Sensor. Buy part #5016501KW2002A at Sears parts store.
Iinstructions on how to replace:
1 Open rear panel. Take 17mm nut off (it's the only one)
2 Pull off what looks like a goofy hubcap (it's held by magnets)
3 Unscrew the six 10mm bolts and gently lower the coils
4 Remove and replace the Hall Sensor (plastic comb looking thing)5 Plug in the sensor and re-install the coils and cover.
30 minutes for me.
Test spin cycle if desired by following chart on page 19 of service manual at http://www.appliancefactoryparts.com/content/pdfs/125448.pdf
(note lower models skip step 10 (heaterIt fills but does not - 2_bing.gif test).
Hall Sensor Part labelled as K351 in diagram on page 41 of service manual.
My machine cannot spin and drain water, it keepson displaying the LE sign which I have investigated to be unclosed lid signal. So how do I fix this problem
If the lid is closed and an LE error is displayed, the lid switch may be defective and will have to be replaced.
May 04, 2016 | Washing Machines
My LG WM2301HR front load washer fills fine and rotates In both directions as it fills but will not rotate during the wash cycle. It vibrates a little like it wants to but then stops all together and...
LE = Locked motor Error
• The connector in the LEAD WIRE ASSEMBLY is not connected to
the connnector of STATOR ASSEMBLY
Reconnect or repair the connector
• The hall sensor is out of order/defective.
Replace the STATOR ASSEMBLY
Sep 18, 2014 | Washing Machines
Just moved front load beaumark washer into a new house, and it won't fill with water. the display lights up and you can here washer trying to fill (humming noice). All display lights come on and it...
It sounds like your water inlet valve is either not getting a signal to let water in from your control board or the water inlet valve is defective. Since you are hearing a humming noise, I would say that the water inlet valve is defective or has been damaged in transit.
Jun 18, 2011 | Frigidaire ATF6000ES Front Load Washer
J'ai par erreur désinstallé mon scanner
Commence par deleter Director Player . Va ensuite sur Device manager ( gestionnaire des p?riph?riques ) et delete ( pas seulement d?sinstaller ) le pilote du scanner .
D?connecte le scanner . Va dans le Control pannel ( panneau de configuration \ programmes ) et delete le logiciel de ton scanner . Fais un restart .
Ne connecte pas encore le scanner . R?installe le logiciel pilote . Fais un restart . Attends que le systeme d' exploitation soit compl?tement stabilis? .Reconnecte le scanner et attends confirmation que le pilote est correctement install? . Cela devrait marcher ? pr?sent .
Si oui , r?installe Director Player et vois ce qui se passe .
Dec 13, 2010 | HP ScanJet 2300C Flatbed Scanner
Code "LE"
Here is a tip that will help you understand the LE code...
heatman101
Apr 21, 2010 | LG WM0642H Front Load
Whirlpool white magic h65 model.what is LE. AFTER
LE error will get displayed when the Lid is opened. Close the Lid and this will get resolved. Similarly you will get FE when the water is not flowing properly into the Machine its a Fill Error.
Nov 05, 2009 | Whirlpool Washing Machines
LE code flashing on WM1812CW
LE code is overload on motor. This unit actually has a magneto and stator. This is what needs to be replaced. Usually find a magnet cracked.
Aug 27, 2009 | LG WM-1832C Front Load Washer
I get error code le on LG dishwasher.
hi,
le means locked motor disassemble the filter and work your way down to the macerator(steel chopper blade) remove it and see if the side labeled "this side up" is really up, its in english... dont think the chinese labourers paid attention to the warning cause i have seen alot that were wrong way
if it was installed correctly order the complete motor/sump assembly btw you do know LG d/w came with a 2 year warranty right? and some of the water distribution system had a longer limited warranty
read your manual, it states warranty, then price the part, then call warranty depot to ask them their service call and labour to install motor/sump
This part taken from a LG repair manual:
(Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.)
good luck.........
Mar 12, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LE light on...not filling with water.
ACCORDING TO SERVICE MANUAL, THE "L.E." ERROR CODE SUGGESTS A LOCKED ROTOR ON THE WASH MOTOR. CHECK THE WASH IMPELLER FOR A FOREIGN OBJECT. IF IT SPINS FREELY, CHECK THE WIRING TO THE WASH MOTOR FOR LOOSE CONNECTION.
THE L.G.HAS HAD A HISTORY OF MOTOR PROBLEMS.
YOU SHOULD BE ABLE TO CANCEL THE PROGRAM AND DRAIN OUT THE WATER.
Apr 03, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
