Question about Cuisinart SM-55 Stand Mixer
Dough hook stuck immediately after use - Cuisinart SM-55 Stand Mixer
I just got my dough hook unstuck! The problem was the bolt at the top of the dough hook. This bolt is used to adjust the height of the dough hook. This bolt came loose while mixing and went up towards the mixer. The force of the spinning actually tightened this bolt against the mixer so when I tried to release the dough hook by lifting and turning, it wouldn't lift. The bolt was in the way! The solution is to loosen this bolt. You'll need a thin wrench that's about 15 mm. You can test loosening this bolt on the other attachments since they loosen in the same manner. You'll have to bend the white shield down slightly to get the wrench in there. It's a tight squeeze even with a thin wrench. Hold on to the lower end of the dough hook and turn the wrench counterclockwise when looking down at it. Once you loosen the bolt, you'll be able to turn the lower portion of the dough hook to lower it. Then you can lower the bolt further. Once you have them low enough, you can remove the dough hook like normal - lift and turn. Sure beats boxing it up, shipping it for repair and paying for shipping both ways!
Posted on Oct 05, 2010
  • koriand3r Oct 05, 2010
    I realized one thing. If the bolt has moved up and jammed itself against the mixer, to loosen it from the mixer, you may need to turn it clockwise instead of counterclockwise like I wrote above. Counterclockwise will cause the bolt to rise - loosening it from the lower part of the dough hook. Clockwise will cause the bolt to lower. Any way, practice on the attachments that aren't stuck since the bolt and shaft are exactly the same on these.
  • Ian Stevenson Sep 02, 2012
    I had the same issue and came to the same conclusion that you did. Since adjusting the hook I have had no further problems.
    Problem Solver:
  • 5 Answers
I don't have a solution. Stuck dough hooks seem to be a problem on this machine. I unsuccessfully tried getting my dough hook out of the SM-55. To do this, I unscrewed the bottom portion of the hook from the top portion - which is actually a bolt. In my latest communication with Cuisinart, owned by Conair, is that unscrewing the dough hook voided the warranty. Bull. So Cuisinart/Conair doesn't have any excuses for avoiding its warranty obligations, just send it back to them without touching it.
Posted on Aug 11, 2010
  • koriand3r Oct 03, 2010
    I have this problem. I can't get the dough hook off but I don't want to pay for shipping for such a heavy product to fix such a simple problem. Anyone else know how to fix this?
    Did unscrewing the bottom portion of the dough hook help you get it off?
    I don't think this should void the warranty because right in the owner's manual it states to loosen this bolt to adjust the height of the other beaters. That's why the bolt is there. I don't see why loosening the bolt to adjust the height would be OK but loosening the bolt to take it apart would be wrong.
2 Suggested Answers
SOURCE: The dough hook is stuck in the beater shaft of kitchenaid mixer
It sounds like it got overloaded when you last mixed dough. It will only come off the way it went on. If it has been bent on, it may need a bit of gentle encouragement.
Posted on Jan 24, 2010
Dough hook will not come off
I had the same problem too. There should be maybe 1/4" of loose vertical play of the dough hook (or similar attachment) on the agitator shaft. The hook locks in place rotationally on the shaft until it is pushed up. Before you try to turn the dough hook backwards in an attempt to remove it, push it upwards and hold it up, then rotate.
May 22, 2012 | Hobart A200 Stand Mixer
Cannot get dough hook out of slot pin seems stuck
run under hot water over where the dough hook attatches to shaft. this should free it.
Apr 23, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Having a hard time removing the dough hook on the h-600.
make sure the beater shaft is clean. is the dough hook new or old if its new you can deburr inside of dough hook to ease in install and removal of attch. please let me know so i can futher asist
Dec 03, 2009 | Hobart H600 Stand Mixer
Jun 15, 2009 | KitchenAid KSM50PR Professional Series...
My varimixer R30 hook doesn´t seem to reach out far enuff to mix satisfactorily. Can the hook change shape just like that ? Or is the hook for some other kettle ?
This is a dough hook and would typically only be used to knead dough. Therefore, the extra clearance makes sense for kneading dough. For other mixer jobs, use other attachments.
Mar 06, 2009 | Food Mixers
Dry clumps in pizza dough
Hi. You should consider a few things. They type of hook you use, can greatly affect your end result. If you're making a yeasted dough with a high protein percentage 12-13%, you should be using an "ED" hook, this is a spiral hook that has a sharp turn at the tip. You can find them on eBay for a competitive price. I believe that Hobart also sells them, but for a higher price. They are very good for mixing pizza type doughs, they also do an excellent job kneading the dough.
Have you checked the flour for lumps before it goes into the mixer? Have you tried sifting the flour?
Are you adding all the liquid and flour at once? If so try adding flour in stages to all the liquid. If you find that this solution helps you, please rate it. Good luck! ricardok45
Feb 19, 2009 | Hobart D340-6007 Mixer
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
Help with removal of Dough Hook on A200.
Force and a torch is your path.
First cut a block of wood that is of a length that is long enough to go from the column to the attachment portion of the planetary. (The block protects the gears from the force.)
Look at the rotation of the hook, you're going to twist it the opposite direction. Above the hook, loop a strand of a wet towel. While keeping the towel damp, not wet, torch the **** out of the hook. I recommend "mapp" gas. Heat it for about 90 seconds to to 2 minutes. The old dough stuck inside will burn off. You should get some black smoke. Use the block of wood, between the attachment portion of the planetary and the column, to resist the twist of the hook. If the wood is properly placed to absorb the load --- dampen towel, torch, block, TWIST. If you use a wrench -- be cautious. Good luck -- Mike
Jun 27, 2008 | Hobart A200 Stand Mixer
Dough hook
if you r using it for dough use the roller and scraper it works much better. But if u want to use the dough hook the holes in the middle is where the knob and stick in the arm go into to hold the hook inplace and it also goes in the hole on the side near the scraper hope this helps
May 30, 2008 | Magic Mill DLX 2000 Stand Mixer
Cuisinart SM-55 Stand Mixer Logo
980 people viewed this question
Top Cuisinart Food Mixers Experts
Ross Keen
john h
Are you a Cuisinart Food Mixer Expert? Answer questions, earn points and help others
