Question about Sport & Outdoor - Others
Pool cleaner Great White GW9500. travels in a straight line only, will not spin or turn. gets stuck on pool steps. no obstruction at pop up brush. do i need a gear?
  • 2 more comments
  • pgugs May 06, 2010
    joe, the brush does not move down into the turning position. there is nothing obstructing it, as i've stated. what i need to know from you is what parts do i need to replace? i already spoke with a great white tech. with poor results. so if you can't tell me what parts to replace, i can't accept your solution. regards pg.
  • pgugs May 07, 2010
    the previous expert states he's not an expert. is there an expert who has knowledge of the pool cleaner in question? if not, maybe a refund is in order.
    I've read the guide several times before i contacted you people. as you may have noticed there are a fair number of parts inside this unit. my sole purpose in paying you all was to find out which parts would cause the problem i'am experiencing. apparently, thats not going to happen. so, at this time, iam requesting a full refund. thank you.
  • Bob Wiseman
    Bob Wiseman Jul 02, 2014
    I had this problem, it was caused by one tooth missing from a gear. This is an easy fix, but be careful when taking it apart, be sure to note were the gears go. You should also see if the rubber skirt needs replacing, note that it has to go on facing the correct way, so be sure to note the way the existing skirt is attached.
    President:
  • 1,070 Answers
Just try to Read this Guide...(This may take few minutes to load according to Connection Speed )
Hope this make you better....Thanks for Contacting FixYa...
Posted on May 07, 2010
  • 10,865 Answers
Hello. While the cleaner is running, turn it upside down under water and check to see that the turning brush moves into the "down" position with in about two minutes. Here is a link to the manual to explaint this further. http://www.starite.com/pdf/S364(12-3-03).PDF
If it is working properly it will clean the pool floor but it is not designed to clean steps.
It may well need the gear you speak about. Confirm that with the great white technician at 800-752-0183
Posted on May 03, 2010
Even if you see the lift brush moving up and down it may be worn out. Mine went in a straight line or stuck against the pool steps. Ordered lift brush ($26) and now it works great.
Posted on Feb 25, 2013
    Genius:
  • 1,354 Answers
Go to folowing link you will get your solution
http://www.patiopoolsaz.com/downloads%5Cmanuals%5CGreatWhiteOM.pdf
Posted on May 08, 2010
    Genius:
  • 1,040 Answers
Dear Pgugs,
Although I am not a expert in this gadget but Still I thinks the Page no. 7 (viz. Troubleshooting") of the owner's manual will help you....
Posted on May 06, 2010
Hoover steamvac 50 stopped spinning
Hi! The brushes can stop spinning if something is obstructing them such as carpet fibers, hair, dirt or debris. Remove the brushes from the cleaner by grasping the plastic outer housing and pulling firmly away from the cleaner. Remove any debris and run it under running water to clean. On the back of the brush-block assembly there's a plastic drive pin that rotates all the brushes when turned. Turn the drive pin and ensure that all brushes are making a complete 360° degree turn. If the brushes are getting stuck or if a brush falls out then the brush-block will need to be replaced. Follow the link here to order a replacement brush-block for the Steamvac Search Results. Below is a list of models this brush will fit.
F5912-900, F5914-900F5915-100, F5915-900, F5915-905, F5917-900, F5918-900, FH50041, FH50042, FH50043, FH50044, FH50045, FH50046, FH50047, FH50048CA
Hope this helps!
Jun 20, 2014 | Hoover Vacuums
My Gw9500 won't climb all walls in my pool
get one of your kids to do it by hand. Those things never do anything except destroy your pool and income.
Jun 10, 2014 | Pentair Kreepy Krauly Great White GW9500
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Phantom does not move gets stuck in one spot
Is the cleaner getting stuck at steps, corners, etc? If so, your spin out is too short. Change the cam to the "winter" position to increase the pool cleaners spin out.
Aug 22, 2010 | Hayward Phantom Pool Cleaner Complete with...
My Pentair legend pool cleaner is not moving
On this automatic pool cleaner, this is usually an easy thing to fix. First, make sure that your filter bag is clean and free of obstructions. Next, take of your head float and shake it. If you can hear water inside, you will need to order a new head float and install it. They are usually inexpensive and easy to replace. Make sure the hose floats are evenly placed and make sure that the cleaner is not getting too much pressure from the return lines.
May 25, 2010 | Pentair White/Gray Legend Platinum...
Suction is great, maybe too good. unit does not
Your probally right about the suction being too much. If you have a main drain and it get's stuck there you need to shut the drain off as the two suctions will stick to each other. If it get's stuck in random places then you just have to much suction to the unit. You can test by slowley pulling two of the hoses apart to let some of the suction escape. If this fixes it you can purchase a dirveter to mount where you mount the cleaner. Their may be one in the box your cleaner came in, so be sure to look there first before spending on a new one.Good luck.
Dec 19, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Gets stuck on walls
turn down the suction if thats not the problem under the left rear pod on the body housing youl see a little straight slot for a screw driver theres 3 settings it actually shows images like a ladder turn the screw down to the first step that should solve your problem
Jul 17, 2009 | Hayward Navigator Pool Cleaner
Sport & Outdoor - Others Logo
2,642 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
