Question about Philips J44414
Wires came loose on a Phillips SIC475027
....could you tell me where they go?. there are red, blue, black, green and white wires
They just came lose and I think I can solder them back on the circuit board
  • Philips Master
  • 2,130 Answers
1st You download Webcam Driver.
camera After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Posted on Dec 24, 2013
I nide doulord web camora but i dont hava a cd for.
Posted on Nov 05, 2008
Lead/pads on th left -- From the top
blk
blu
grn
wht
red
Posted on Apr 11, 2008
  • Towertops Apr 11, 2008
    Follow-up suggestion:
    Factory solder job was extremely inferior. Mine were "cold solder" joints. The slight strain and they peeled away from the pads. If you remove the factory solder (with ******), you expose 5 "plated through" (the PCB) holes which will accept the leads.
    Best of luck.
    How about that. I referred to a "Soldersucker" a trigger tool that inhales the solder and works better than solder wick. The system censored me. Go figure!
J'ai perdu mon drver de cam
manula de camara sic4750/27
Posted on Apr 03, 2008
Wiring for 6 pin oricom mic plug
I too have an Oricom 6 pin mic with wires broken pin 1 is white, 2 is black and 5 is screen, this does not match any of the above answers and the green blue & red are off with 2, 3, 4, & 6 available
Kevin H
Jun 03, 2013 | Radio Communications
How to connect the wires of electric fan
White to white.black to black,green to green & blue to red. If no light then just cup off blue.I no red in house wiring then put black & blue to house black.This is all I can tell you with the info . you gave.
Feb 14, 2013 | Dryers
Only have two wires to connect to
What timer are you installing?
Intermatic battery-operated timer with red, blue, black and green
Green connects to bare ground
Red is capped off.
Blue connects to one wire
Black connects to other wire
Push on-off button: if light comes on, timer wiring is correct.
If light does not come on, then reverse blue and black wires.
Other in-wall timers except Aube have red, black, white and green
Green goes to bare ground
Red connects to one wire
Black connects to other wire.
White: in back of electrical box are white wires twisted together and covered with wire nut. Connect white white to these other white wires.
If box does not have white wires described above, then connect white wire to bare ground along with green wire.
Push on-off or override switch: if light comes on, timer wiring is correct.
If light does not come on, then reverse red and black wires.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
I need help wiring my fan. I can't get the fan to work, but I do have the light working. From the ceiling I have a white, black, red and ground wire. How should these wires connect to the White, Black,...
White is your neutral so white goes to white. Blue on the fan is for the light kit you need to wire that to the wire from your switch so it works the lights. Black is the hot wire that is always hot not switched so tie that to the wire that is not on your switch. Green is ground so green to green. white to white / green to green/ black to black/ red to blue/
Nov 06, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Tv went to black and white
It may be a wire has come loose. Check your video inputs. Especially if you have animals or small children. On certain video inputs you lose color if one wire comes loose.
Jul 20, 2009 | LG RU-44SZ63D Television
I am converting a 3 prong dryer to a 4 prong plug. The wires inside the dryer are black/yellow, white and blue. The wires on the plug are white, black, red and green. I am assuming the green is the ground...
on plug white is neutral, black is power , red is power, green is ground. black/yellow and blue are power and white is always neutral ie. (white to white) black to black/yellow, blue to red. green to grounding screw on machine
Jan 04, 2009 | Estate TEDX640JQ Electric Dryer
RADIO INSTALLING
there is a code for color!? ok, wait im searching...
found it! here you go, hope it helps...
Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
Jun 19, 2008 | 2001 Chevrolet Tahoe
Philips J44414 Logo
172 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
