Question about Dishwashers
My dishwasher leaves everything dirty and also the washing tablet is not being used just flipped out,just sitting there @ end of wash, have tried unblocking the hoses but still same problem. carmar74
    President:
  • 949 Answers
It sounds like the pump is not working right, there could be many reasons for this. Could you get me your model number from the tag just inside the door? This will help to direct you what to look for.
Thanks!
Posted on May 03, 2010
Testimonial: "thanx 4 that my model number is 6ADP 8540 1X type: NGPN,if this helps carmar74"
Front end loader
are you using the correct detergent and not to much for this machine-try cleaning out the drain trap and filter-wipe down the door seal and tub with a bleach or oxy type cleaner -run the sanitizer cycle with a quarter cup of powdered dishwasher soap,and finally leave the door open between loads-this ain't your momma's washer-these things can be a pain in the booter-cheers Denny
Oct 26, 2013 | Samsung Washing Machines
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
May 19, 2010 | Dishwashers
Washing tablet found unused on the bottom of the dishwasher...
Put the tablet in the bottom of the washer ,do a wash cycle,if the tablet is used up the washer is not releasing the tablet till the end of the wash, if the tablet is still there the water is too hard or the tablet is faulty.
Nov 29, 2017 | KitchenAid KUDK03ITBK Built-in Dishwasher
Doesnt dry dishes, top rack not clean, has been serviced 3 times
If you have checked everything that was mentioned (and none of them are the issue) then either the heater inside the unit is not coming on during the wash and rinse cycles and/or the fan motor inside the door is not coming on during the dry cycle. A technician can easily check this out with the correct tools and by putting the unit into test mode.
As for the top rack dishes being dirty and there being soap left in the dispenser, this sounds like wash motor is either weak or the vario motor is not switching between the upper and lower spray nozzles. The sump assembly should be replaced for this issue.
Jan 18, 2009 | LG 24 in. LDF7810 Built-in Dishwasher
Bad smell
Try running washer empty with soap or tablet in the regular cup and baking soda in the secondary cup. After cycle is complete and somewhat dry inside leave slightly open to allow air circulation overnight. This should help.
Sep 15, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Jul 06, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Hotpoint BF1620
What you will find is that the plastic nut fixed on the back panel that the top drawer pushes into has lost the rubber inner layer. Replace and your problem is solved
Kamal
Apr 15, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Top rack dishes are not clean
My Whirlpool dishwasher is only 2 years old and I started having the same problems. I dismantled everything I could and washed and scrubbed the entire unit with EVERYTHING..to no avail, dirty dishes!! But I discovered a remedy! Try using Lemi-Shine for about a week with your regular wash-soap. If you are using the tablet form of soap, stop and try the powdered form. Follow the instructions on the Lemi-Shine container. You can find it just about anywhere for around $3.50. I was within "5 seconds" of replacing my 2 year old Whirlpool dishwasher when this caught my eye and I figured why not try it too? After the first wash I noticed a big difference the cleanliness of the dishes..and now it is running GREAT after 2 weeks!
Aug 21, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher tablets not dissolving
It may just be the way you are loading the machine.  If the dishes are not allowing the the detergent door to open fully, the tablet sits in the dispenser until you open the dishwasher, letting the dispenser door open and the half dissolved tablet falls out!     Try being more careful how you load the machine or just chuck the tablet in the bottom of the machine instead of the dispenser!
Apr 10, 2006 | Bosch 24 in. SGS66E02 Exxcel Built-in...
Dishwashers Logo
87 people viewed this question
Top Dishwashers Experts
