Question about DCS PHFS Phoenix III Outdoor Patio Heater
Need a grill and hood - DCS PHFS Phoenix III Outdoor Patio Heater
My 1999 tyahoe hood latch and cable doesnt work how can iopen the hood
have someone push down on hood and try to open ---- reach behind the lever and disconnect cable use a vise grip to pull cable if cable is broken---- than behind grille is latch look through grill and will need a metal hook to grab cable and pull cable towards grille and pull through cut cable cover back and pull cable back
Hood latch won release ChevyTalk FREE Restoration and Repair Help for your... how to open hood from outside when cable breaks
Jul 28, 2016 | 1999 Chevrolet Tahoe
1980 Malabu . How can I open the hood. The hood release does not work.
Someone would need to reach up between the grille and the radiator to move the hood latch lever. You may have to remove the grille to access the latch.
Oct 03, 2012 | Chevrolet El Camino Cars & Trucks
How do you open the hood of an AMC 76 Pacer?
use a flash light shine it center front grille where hood is.look down center hood where grille is you should see small opening where your hand can fit through to open the hood latch.i remember most 70s cars you open hood from outside around front grille area.
Nov 21, 2011 | Cars & Trucks
Broken hood release lever under steering weel. Need to open hood to jump start vehicle, to get it to service bay. How can you open hood without hood release lever?
try to see if you can remove the grill, often times the grill is held in by screws accessed from the front of the car-if that does not work, you will probably have to get under the nose of the van and reach up to grasp the cable end (use vise grips) and pop the hood. Try the grill first though, use a flash light to carefully see if it can be done that way.
Apr 18, 2011 | 1995 Plymouth Voyager
Hood wont open
If when you pull the hood release, the hood doesn't pop up, have an assistant lift the hood while you're pulling the cable release. If this isn't helping, you can remove the grille out of the grille surround... look for attachment screws.. once the grille is out, you should be able to release the hood latch from the underside with a screwdriver.
Nov 16, 2009 | 1996 Mercury Cougar XR7
1995 isuzu rodeo hood release broken under the hood
if the grille screws are accessable remove the grille which should give you access to the underside of the lock, you may need a screwdriver to push the lever aside to release the hood
Hope this helps
May 23, 2009 | 1995 Isuzu Rodeo
Hood latch
There is no other way to release the hood other than either trying to reach the latch release from under the car or removing the grille.
Jul 28, 2008 | 1993 Acura Legend
Heating & Cooling Logo
32 people viewed this question
Top DCS Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a DCS Heating and Cooling Expert? Answer questions, earn points and help others
