The cold water pressure is very poor into our LG top loader washing machine. There are no blckages and the water comes out of the tap fine. The hot water is ok.
  • 555 Answers
Remove the hose from the water machine. there is a iron mesh that traps foreign objects from the water tap. Perhaps it is quite dirty.
Posted on May 03, 2010
LG Top loader WF-T7016PP Won't take in cold water? Help please
turn tap on at the wall
check that the water in solenoid is operational
check that the stop washer in the tap is allowing water in to the machine
check that the water level is set correctly
call a technician does water flow if hot water is selected
Jul 10, 2016 | LG Washing Machines
My new LG front loader washing machine makes humming-buzzing noise when starting (only hot washing from 60C and above)
it is buzzing because it is try to let in hot water and is activating the hot water inlet valve/solenoid
Sep 06, 2015 | LG Washing Machines
WI815 Intuitive Eco - no cold water
IW Intuitive Eco.
Water valves have a rubber diaphragm that wares out
after some time,
So yes you are right water valves need replacing.
Apr 21, 2014 | Fisher and Paykel Washing Machines
The model of my LG WASHING machine is WP 750((N,R)(P) AND IT IS A TOP LOADER,THE SPIN BASKET WORKS BUT THE WASHER ISNT WORKING.
Sorry but your description of 'isn't working' has very little detail in it so I am trying 'poor water fill' first:-
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 14, 2011 | LG WFT1071TP Top Load Washer
Hi expert, I go PE error in LG 6.5 intellowash ,top door washing machine ,kindly help me to solve the same ...nagesh
LG's 'PE' stands for 'Pressure Error'- poor water feed.
John C
Jul 19, 2011 | Washing Machines
My fisher paykel top loader won't do a cold wash.
Hi just read your posting.Have you selected cold only?Are the hoses from the taps going to the correct water valve?Cold tap to c on the machine and hot tap to h on the machine.What is the model number of the machine?The model number sticker is on the back of the machine up top.Please reply with additional information and I am sure I can help rectify the fault.Looking forward to your reply/
May 20, 2011 | Fisher and Paykel Washing Machines
Water flow very very slow though the pressure from main tap is fine
almost certainly not a fault with washer. check small filters in the fill hose and make sure hose not kinked
Jul 18, 2008 | LG WFT1071TP Top Load Washer
Washing Machine LG WD-1049 C
Growing up in Europe with front loader washing machines I thought I only had to hook the machine up to the cold water tap and it would heat the water up to the required temperature. However, this model needs to be hooked up to both the hot and the cold water tap in order to function properly. Everything is working fine now that I have done that.
Apr 02, 2008 | LG Washing Machines
Hoover 750L top loader washing machine
I had this problem. I alternated the hot and cold water valves (changing over the wiring) and then hot tap then dribbled instead of the cold. Replacement part i believe is around $35AU
Dec 29, 2007 | Washing Machines
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
