Question about Yamaha Audio Players & Recorders
Yamaha R3 receiver - sound cuts and crackles in one channel - not a speaker problem. Any advice?
3 Suggested Answers
techman
  • 3130 Answers
SOURCE: Losing volume on channels
I am afraid not. That crackling is a component in one of the solid state amp circuits starting to fail. These are all soldered into the printed circuit board. This could be a difficult repair to find an intermittant component. Depending on how old the unit is and how much it cost will factor in on if you have it repaired or not. Rule of thumb is that if the unit is two to three years old and cost less the 200 to 300 bucks you should not invest more then 100 to 150 bucks into it. Good Luck
Posted on Mar 16, 2007
SOURCE: Speaker imbalance in Yamaha HTR-5630
how do i hook up a yamaha natural sound av receiver htr 5630
Posted on Aug 05, 2009
Sherwood Rx4050r and right speaker has crackling noises.
Ahh, that channel is blown. Its not 100% blown. This has happened to my freind before, and from my long knowlage in audio, the channel is blown, and is not fixable. If you REALLY are attached to it, you could probably bring it to a shop that fixes receivers, but best bet is to let it go
Oct 12, 2009 | Sherwood Audio Players & Recorders
Toshiba 42H81 speaker crackle
It could be the board or the speakers itself.
Check see if ur air tv have any crackles?
If not u can rule it out the speakers.
Tries it with diffrent cables,see what happen.
The prob.still there it ur electronic board.
Aug 27, 2009 | Toshiba 42H81 42" Rear Projection...
My center speaker crackles
Try connecting one of your other speakers to the centre channel on the amp to see if it is the speaker or the Reciever. If the speaker does not crackle then chances are the centre speaker is probably blown and will require replacing.
Jul 30, 2009 | Yamaha HTR-5730 Receiver
2 month old ONKYO TX-SR706 speaker circuit problem
This is a problem with the surround sound processing. Effectively the digital signal is not being processed properly. Since this unit is so new, return it and request either an exchange or at least warranty service. The DSP board will likely be replaced.
Dan
Feb 16, 2009 | Onkyo TX-SR605 Receiver
Yamaha rx-v2200 sound problem
Hi Zanthena - my Yamaha rx v 2200 is doing exactly the same thing - did you manage to track the problem down? I have had my unit in for repair and the fault occurred again 6 hours after I re-installed it.
Any help would really be appreciated!
Jason.
Sep 07, 2008 | Yamaha RX-V2200 Receiver
No output from left channel after crackling sound
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Jul 08, 2007 | Marantz SR-4200 Receiver
Crackling sound when changing channels
Check the connections to the speaker and the receiver. Had a loose connection once that did the same thing.
Apr 15, 2007 | Definitive BP7001SC Main / Stereo Speaker
290 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
