Question about Dewalt DPD3300 Commercial Pressure Washer
Engine does not start easily after shut off - Dewalt DPD3300 Commercial Pressure Washer
  • 52 Answers
If there is water pressure still hooked up then pump is primed and a sensor { that kicks the idle down when not pulling the trigger} is restricting the fuel flow. see if problem continues without pressure
Posted on May 03, 2010
Hi My 2005 Same Dorado 85 Tractor. It starts from cold easily first time around. But once the engine has been running for several minutes it stops.
sounds like you could have a coolant temp sensor issue. If it senses the engine temperature higher than it actually is, it will tell the engine computer to shut down.
Also I'm not showing an 05 Eldorado, if you could give the correct information for your car, it would be very helpful
Feb 15, 2017 | Cars & Trucks
I have a 18hp kohler it starts and ruins for 5/ 10 seconds and them shuts down and there is a cloud of white smoke
Air cooled engine ok ,
When the engine shut off did it white smoke out the garden it could be the head gasket
Low compression and it won't start poor compression and it might start but run poorly stall easily and white smoke produce because of unburnt fuel escaping into hot exhausts and vaporizing
Jul 03, 2016 | Garden
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
Carburetor leaks after engine is shut off
Your carbs bowl float is sticking allowing the gas to continue to flow when the engine is not running.And if you say it is ruining into the engine..check the oil for the presence of gas..if so change the oil,oil filter and remove the plugs and cover the tips to stop spark..turn the engine over to blow gas from the cylinders using a rag to catch the fluid...now to the fix..either take the carb apart and clean all the parts but there is no way to know if this will happen again..this has happened to my Husky. The best and easy fix is to install a inline fuel shutoff valve..where you can get at it easily...Just shut it off and let the engine use up the carb fuel..and when you start it again turn on the shut off valve let it set until the carb gets full about ten seconds..then start the engine...just got to rmember to do this every time you shut it down...works well for me...good luck.
Feb 06, 2014 | Briggs & Stratton Garden
Every time i start my dirt bike it starts then shuts off
You likely have a dirty carb. Take it off and clean it. If you don't have the skills take it to someone who does. Things to look for include a needle and seat obstruction, the float not set at the proper height. You might also need to flush your tank out and clean the fuel lines. If the engine starts easily and then shuts off it sounds like there is no fuel getting to the engine. You let it sit, and the fuel fills back in to the carb bowl, but not enough fuel getting there to sustain the engine so it dies. Hope this helps. There are things you should have told in your description like: Whether it starts easily at first, how long does it run, does it start back up after dying right away or do you have to wait, is there any other symptoms like excess smoke; sputtering, noises, etc.
Nov 08, 2013 | Jack Hydraulic Clutch KX85 KX250 KX500...
2003 altima hard to start when engine is warm
replace coolant temp. sensor , disconnect coolant sensor plug after engine is at running temp. ,shut engine off then restart ,if engine starts fine, replace coolant sensor
Jan 28, 2013 | 2003 Nissan Altima
99 escort fuel pressure slowly drop to 0 after shutting off. turns over longer before starting. What holds fuel pressure after shutting off?
Hi Rusty, The fuel pressure is regulated by a special device on the end of the fuel rail. (That is the fitting on top of the injectors and carries the fuel under extreme pressure) If the regulator is leaking it will allow fuel to by pass and return directly to the tank. You can check it by squeezing the rubber fuel return pipe with pliers while the engine is running, or before starting. Crank the engine until it starts and then clamp before turning off. Restart the engine and if it starts easily you'll have located the defective part. Regards Johngee10
Jul 23, 2011 | 1999 Ford Escort
WHILE I WAS DRIVING THE CAR IT STARTS TO SLOW DOWN HAS NO POWER BUT WOULD EASILY STARTS EVERYTIME IT SHUTS DOWN, ONE PERSON SAID HAS TO DO WITH THE FUEL [PUMP
Does it drive for a little while before it shuts down? If so it could be the catylitic converter. If a converter gets cloged up it will cause to much back pressure and the engine will bog down.
Feb 11, 2011 | 1997 Lexus LS 400
I have a roll air compresor its the weelbarrow type gas powerd wen i start it it fills up then it shuts off it will start again wen tanks are empty and the prosses has to be repited over an over
The pilot valve controls the pressure, idles the engine when set pressure is obtained and releases compressed air thru small vent while the engine is idling. If the idle is set too low, the engine may stall. Try increasing idle speed and make sure that when set pressure is reached that air is venting from pilot muffler vent. The pilot valve can be easily tested. With engine off and pressure in tank, flip the pilot valve start lever up then down. When flipped up, the throttle control shuld activate idle and the pull rope should be easy to pull. With lever down, throttle is pulled on engine and compressor is loaded making the rope very difficult to pull. If the engine stalls with air in the tank flip lever up to easily start engine then down to pump. Good holidays
Dec 19, 2010 | CRL 4hp Gas Powered Compressor
Honda GC190 engine shuts down on my Karcher 3000 PSI PW
Well would you believe that I have the very same problem. I suspected that the pump was seizing up, so we tried the pump on another unit and it worked fine. On inspection of the motor we found the cam (which also operates the decompression mechanism) was worn out. It's made of hard plastic. It is only about 7 dollars too, so cheap enough to fix. I have mine ordered now and feel pretty confident that that should fix it.
Aug 13, 2009 | Karcher 2500 PSI Pressure Washer
Dewalt DPD3300 Commercial Pressure Washer Logo
176 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
