Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Position for rinse aid
Where do you put the rinse aid in the dish drawer?
  • ken_sue_alli May 03, 2010
    Thank you for your help but I cannot access a manual. The door comes open and there are two trays inside, a large one and one about half the size. However in the middle if the panel there is what looks like the lid of a tank. I has a red light in the lid. Is this where the rinse aud goeas?
  • Fisher and P... Master
  • 3,247 Answers
  • 713 Answers
Open the little lid and fill the tank with rinse aid. the red light will turn off when it is full. please do not over fill or spill any. please reply 4 more help good luck
Posted on May 05, 2010
  • 901 Answers
Pl refer the user manual. Rinse aid is not a day to day to fill. It has a different location. Open the door and see whether you get any box visible!
Posted on May 03, 2010
How much salt goes in dish washer
You don't put salt in a dishwasher unless you want to ruin it.
2. You ONLY use a detergent specifically for dishwasher use as the cleaning agent and you 3/4 fill the soap dispenser in the washer (normally fitted into the door on the inside) with the dishwasher powder.
3. If there is a separate small compartment in your dish washer for a "rinse aid" solution to be used, you can use a rinse aid product designed for dishwasher use only. If there is no rinse aid compartment (this is also normally fitted to the inside of the door - if fitted on your machine) then you cannot use a rinse aid in your washer.
4. Don't use any other product in the dish washer.
Jan 30, 2016 | Dishwashers
Where to put rinse aid in cdw10 dishwasher
Rinse aid makes dishes sparkle more as it improves their drying. The rinse aid container is situated on the inside of the door. You should fill the rinse aid container when indicator lights up on the container and the rinse aid indicator light on the control panel flashes. You can use simple vinegar as a rinse aid (white is best but apple or malt is fine).
Adding rinse aid.
To open the dispenser, turn cap anticlockwise. Take care when you pour in the rinse aid to avoid it overflowing. You can regulate the amount of rinse aid used by the dishwasher, move the adjuster which you will find under lid. The amount of rinse aid needs to be increased if the dishes appear dull or you can see circular stains. The amount of rinse aid needs to be reduced if the dishes are sticky or see white streaks.
You can choose from six different positions. It is normally set to 4.
Jun 07, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Rinse aid pours out of compartment
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/590199D%20DishDrawerP7%20userguide%20USCANZAUGBIE.pdf
Maybe you are putting it in the wrong compartment ? Powder in the top liquid in the bottom , you can also adjust the rate of flow for the rinse aid . This manual explains it all .
Cheers
Apr 07, 2014 | Fisher Paykel 24 In. Panel Ready Double...
Dish drawer not drying dishes
According to the manual, there is a cooperative effort with the rinse aid solution and the non eco mode. There nothing that says a drier circuit exists and if they are not drying then it is rinse aid or loading issues. However if you look behind the kick panel of the machine there is a plastic envelope with the technicians information on testing.
Jun 06, 2013 | Fisher Paykel Fisher & Paykel DD24SCTX6
Fischer paykal dishwasher drawer leaving white powder on dishes
If rinse aid levels in dispensor are ok then check if it is being used. the rinse aid setting may be set too low.
Dec 24, 2012 | Fisher and Paykel DD605SS Stainless Steel...
Not cleaning dishes as well as when i bought it four years ago
Apart from checking if the filter plate etc are clean and the rinse-aid dispenser is consuming rinse aid there is something else you can do.
Buy Finish dishwasher cleaning kit from super market (one for each drawer) and run the drawers one at a time as instructed on the kit.
This should help.
Aug 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Film on dishes and inside stainless steel panel
You live in a hard water area. Even though dishwasher tablets have salt included you may have to fill the machine with extra salt. (its the large srew top cap in the bottom of your machine, open it and fill it with dishwaher salt your machine came with a large funnel to help you do this) you will have to remove the bottom drawer to do this. next make sure you have rinse aid installed in the door of your machine, next to where you put the tablets in (don't buy cheap rinse aid it's not worth it) when its full of rinse aid the indicator will turn dark, will need both salt and rince aid about every 30 cycles.
Nov 05, 2009 | Miele Optima G2470SCVi Built-in Dishwasher
The dishwasher was full of soap suds but most of the water drain
Suds? If you use dishwashing detergent you shouldn't get suds. If a small amount of sink type dish soap is left on a dish before loading it into the dishwasher this can happen. I would use several rinse and drain cycles with the racks and dishes removed until the suds are gone.
Never use any type of liquid dish soap made for sinks. The same thing that makes suds in the sink will make even more in the dish washer.
Hope this helps!
Feb 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
I've lost the manual. Where does the rinse aid go in the dish drawer?
the rinse agent will go below the soap dispensor, remove the screw top where a light should be shining through
Oct 31, 2008 | Fisher and Paykel Dishwashers
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
193 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
