Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet we broke the catch that holds door closed on washe
We broke the catch that holds door closed due to overfilling washer. can we replace ourselves?
  • 5,911 Answers
If you are referring to the door latch mechanism on the door facing, the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r3575840-replacing_a_door_latch
If you are referring to the catch on the door itself, it can also be replaced. Just remove the two Torx (T-2) screws that hold it in place and remove. Replace as necessary with a new catch. Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If the model number is correct, the part number for the door latch is 8182634. The door catch part number is 8181651. You can view these parts under the "Door and Latch Parts" heading as items 7 and 9.
If you have any questions, please post back and let me know. I hope this is helpful to you.
Posted on May 03, 2010
The washer door will not lock so the load can start washing. What can be done to make the washer door lock and start washing?
check door switch is functional,will prevent filling and future functions until confirmation of door is closed and locked.Door lock switch will prevent further functions like filling etc if the door catch does not close this circuit.Someone with electrical knowledge should be consulted in conjunction with wiring diagram of same
regards frank
Apr 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not turn on. I tried all the usual
Hello,Copy and paste this service manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Thanks
May 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door will not close
Your door may be twisted or binding. doors like this only need to be out by 2mm to stop closing, from what i have seen, this type of door in the photo tend to twist down with time due to the glass and over heavy things pulling the door hinge down. you can try gently twisting the door up a little.
that or the spring that is in the door catch is damaged and rather then holding the plate to keep the door closed, its pushing the door back out.
Jan 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When I wash comforter in whirlpool duet front load water comes
first an foremost your washer isn't designed to wash comforters, the capacity isn't large enough. only clothes sheets . the reason ur door wont stay closed is the bulk item is pushing it open. overloading washer will cause $$ major problems. simiply take that to the cleaners an save urself some big bucks.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet Washer Model No. GHW9100LW, Serial No. CSM2608446, Type No. 199-AWM075/GY
not unless you make it yourself ..replacement handle is just like the 1 that broke
Aug 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Broken door
You probably have to bad door latch. its easy to replace. it requires i believe a number 20 torx bit you have have to remove the spring around the door boot and then you can put you hands to inside the unit to remove the latch.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Front load Whirlpool Duet
Hi, Has the door catch,which protrudes and goes into the hole, broken off, it should have a sort of hooked end. Tom.
Mar 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
162 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
