Question about Sony KP-53S35 53" Rear Projection Television
I have a Sony KP-53S35 53 inch Rear Projection TV connected to a Directv Receiver. The TV does turn on, but the screen goes blank and VIDEO 1 is displayed. It will stay on, but will continue to do this. Any suggestions would be appreciated. Could this be a problem with the lamp? Is there a part number for the lamp?
  • clubdjg May 03, 2010
    My Directv is set to Video 1. I do not have cable nor an antenna connected so all I see is know when I follow your instructions.
  • 10,594 Answers
Press any channel button on tv remote to switch its input source as TV to watch tv channels.
As you said, screen shows Video-1 display that means tv is set on input-1 that need to be changed, press channel button on remote or tv front to shift it on tv channels mode.
Let me know if you have additional question.
Thanks.
Posted on May 03, 2010
  • Shahid Electronics
    Shahid Electronics May 03, 2010
    OK, so video box is hooked in Video-1
    Please select Video-1 input in TV, check video cable is plugged properly in tv and cable box.
    Unplug cable box from wall socket for couple of minutes to get it reset, replug back in and turn it On.
    If problem still not solved then check with cable company as cable box seems defective.
    You can test tv video-1 input by plugging dvd player video output to get its picture.
    Thanks.
My Sony kp-53xbr35 Rear Projection TV screen turns green for a few seconds when I turn it on, then goes blank. Audio still works. Timer/Stand-by blinks until screen goes green, then stops, even when screen...
check the lamp out if the lamp go to this website http://www.discount-merchant.com or if the lamp is not the issue maybe can be the board in the same page you can find the parts that you maybe would nedd
regards
Dec 18, 2009 | Sony KP-53XBR45 53" Rear Projection...
My sony tv stars blinking 5 times in a row, then the picture goes black for a second comes back then goes black again and it keeps doing it non stop
tv has a blanking picture mute circuit. adjust the screen controls which are located behind the speaker grill in front of set. there will be a access panel to unscrew in center and then you will see a black 4 inch square box with 6 physical knobs. 3 control screen the other 3 controls focus for red, green, blue. turn them down and slowly start turning them up. fixed.
Nov 11, 2009 | Sony KP-53XBR200 53" Rear Projection...
Screen goes black and resets during HD shows
I just posted this to another Sony owner:
Another point; HD Ready does not mean that it is HD compatible without the addition of an optional part.
The title only implies that it can be adapted to HD reception.
If you did not purchase it with the set, check your user guide to see what you need to make it whole.
You may have to seek this add-on on eBay since it is not guaranteed that Sony will still offer it.
You might want to check this:
Technical Details · 53-inch HD-ready rear-projection TV (doesn't include HD receiver); 48 x 57.5 x 25 inches (W x H x D)”
From: http://www.amazon.com/Sony-KP-53HS10-53-Inch-Projection-TV/dp/B000050FGB
Aug 31, 2008 | Sony KP-53HS10 TV
Sony KP-46WT510 Rear Projector TN
Try to hard reset the TV that is Unplugg the device for 30 mins or an hour and then connect it back..It will help you essentially..!..Thank you..
Please post back on how things turned or for further assistance..!..
Regards!!..
Jul 23, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-57HW40
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
Feb 19, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony rear projection tv
Bad green crt, this set has a problem with bad crt's
Oct 13, 2007 | Sony KP-57WS500 57" Rear Projection...
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Home theater reception
you need to unlpug your set and reconnect everything over and see what it does.if that does not work have a tech check your system.your sony recviever is the culprit let that be checked.good luck
Apr 05, 2007 | Sony KP-53XBR45 53" Rear Projection...
Televison & Video Logo
205 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
