Question about Maytag Neptune MDG5500AW Gas Dryer
Heating problem my dryer is not kicking on the gas and heating the clothes.
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
I have a gas dryer, when I turn it on the gas kicks on but when it cycles off it doesn't kick back on and the clothes don't dry
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 30, 2011 | Maytag Dryers
THE FIRST TIME THE DRYER STOPPED HEATING THE CLOTHES THE FLAME DIDNT KICK ON AT ALL. SO WE REPLACED THE HEATING FUSE AND IT WORKED FINE FOR 8 MONTHS. NOW THE HEAT COMES ON BUT DOESNT STAY ON LONG ENOUGH TO...
heatman101
Jan 26, 2011 | Whirlpool LGR4634J Gas Dryer
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
Pilot light goes out about 2 minutes after starting dryer
heatman101
May 25, 2010 | Whirlpool LER4634J Electric Dryer
Gas dry is not heating enough to dry clothes
There is two possible causes. Either your gas coils are going bad late in the cycle or your venting is restricted. I would go outside check to make sure you have good airflow. If you have good airflow outside the only common cause of gas dryers failing to heat late in the cycle would be gas coils. If you have a peep hole on your dryer look in it after your dryer has been running for approx 30 mins and see if the ignitor glows and then shuts off. If the burner does not kick on then you have bad gas coils. They are part number 5303931775.
Let me know if this helps _MJ_
Jan 29, 2010 | Maytag MDG2600BWW Gas Dryer
Dryer burner does not kick on every time that I use the dryer. If I hear the heat kick on, the clothes will dry, but if the heat does not come on, the clothes will tumble on just a cold air dry and the...
Replace both coils on the burner valve . After heating up , they will not open to let gas thru again until cooled down for a short period of time . With no heat , timer will not cut off unless set for timed dry .
Aug 09, 2009 | Maytag Dryers
Maytag atlantis gas dry is not heating up its about 6 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
GE GAS DRYER DDG7189SBLWW NO HEAT?
SOUNDS LIKE YOU HAVE A RESTRICTION IN YOUR DRYER VENT SOMEWHERE. THE UNIT LABORED TO EXHAUST UNTIL THE THERMAL FUSE BLEW. YOU WILL NEED KNOWLEDGE OF THE USE OF A MULTIMETER TO MAKE THE NECESSARY TESTS ON THESE ITEMS, BUT DON'T FORGET TO CLEAR THE RESTRICTION!
Jan 28, 2009 | GE DBXR463GB Gas Dryer
Gas dryer tripping breaker when plugged in.
I have the same exact problem. Dryer works great....when empty. Put wet clothes in and 3 or 4 hours later they are as wet as when I started. I am going to kick the piece of junk to the curb and go get a GE dryer right now.....I suggest you do the same.
Oct 16, 2008 | Whirlpool LGR8648 Gas Dryer
My gas dryer only heats up the first time...
replace both coils on the gas burner (the round black dohickeys)after first ignition they tend not to pull valve open next time heat is called for
Jun 06, 2008 | Hotpoint NBXR463GBWW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
57 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
