Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Sound I am getting picture but no sound. This just happened yesterday.
  • 138 Answers
Unplug the set for about 20 minutesand plug it back in. If that don't fix the issue your small signal board need to be replaced. That is your video processor.
Posted on Aug 19, 2008
I have a 2010 rca tv model 4033 have sound but no picture just happened yesterday
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Oct 01, 2014 | Televison & Video
Argos vp-35r webcam driver
how do i add pictures from webcam to my pictures on windows7??
Feb 15, 2012 | Computers & Internet
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
We have sound and pip but no picture on the big screen. wh just had it serviced because of a leaking something which was fixed and a tray was placed beneath it. when they brought it back yesterday and...
Unpluging the set for fifteen minutes or so, your tv have receive guide information, and sometimes when that happens it will shut the sound down.
Nov 26, 2009 | Mitsubishi VS-45609 TV
No picture, but have sound
hi....Your micro chip is faulty check the voltage comming out of the 42nd leg it shuold be 13 volts dc if you are not getting that voltage replace the microchip.and the eeprom IC....
thank u rate me!!
Feb 14, 2009 | Samsung DLP HL-P5663W 56" TV
No sound on older samsung tv
techs call this a cold or a bad solder connection on the output transistor most likely, tap on it here and there when it happens on the bottom and side of tv, if sound comes in then stops again then it would be a loose connection due to heat over time, if your inclined u can be fixed it, if bad chip it would play first then shut off, or if u have a cable box or rca outputs on tv use them on an amp to get sound, that would bypass amp output and u will use the preamp section which is a different circuit, debgh@comcast.net
Jul 25, 2008 | RCA F19625 19" TV
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
18 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
