Question about Sony STR-DA5300ES 7.1 Channels Receiver
Hooking up my direcTV hd reciever to my sony da5300es
Can i hook up the output on my direcTV reciever HDMI to the sony da5300es input then run HDMI to my tv? if so what input ports/output to use on my sony reciever?
  • 3 Answers
SOURCE: Sony STR-DA5300ES Audio Problem
I am posting this to try and get everyones audio problem for this receiver fixed. If you only connected the HDMI cable to the 510, you will not get sound. This receiver passes through HDMI only, no processing of audio. You must either connect a fiber optic or digital coax to the 510 for that respective HDMI input from the BD player, the DVD HDMI only accepts digital coax, and the Video2 HDMI only accepts fiber optic. If you BD player does not have digital coax out for audio, you must move the connection to Video2 HDMI and connect fiber optic to the Video2 fiber input. Sony butchered the whole purpose of HDMI with this receiver. Hope this heps you. By the way, it is hardware, no firmware update will correct this.
Posted on Jan 27, 2008
smeago1
  • 136 Answers
SOURCE: optical inputs
In short yes!
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
But in short yes to your question.
hope this is not too confusing.
good luck
smeags.
Posted on Feb 05, 2008
  • 4234 Answers
SOURCE: No analog audio out for digital inputs
The easiest way is to connect to one of the tape out jacks. These should be live for all inputs.
Dan
Posted on Mar 26, 2008
  • 3 Answers
SOURCE: Sony STR-DG510
On this model you can't HDMI is a pass though just for video, No audio, you have to run audio with composite red/white, digital coax or fiber toslink
Posted on Jun 02, 2008
welcomejee
  • 10594 Answers
SOURCE: sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Posted on Jan 04, 2009
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
Upgraded older HD TV to a Sharp 70" smart TV & Home Theater Receiver (Yamaha RX-V575. Have AT&T U-verse HD Cable box. What is the connection sequence using HDMI cables. Searched Yamaha and AT&T sites and...
I dont know about your particular hd hookup , but I take the hdmi cable out of my dish reciever/dvr [digital video recorder] and run it straight to the hdmi input #2 in the back of my apex 40 in lcd-hd-tv
I think take the hdmi output from the at&t u-verse cable box and plug it into the hdmi input of your 70 in sharp smart tv
that will get the input signal from your cable box ,both video & audio, into your tv set.
on the back of your tv set
there should be audio outputs for home theater audio systems that would plug into the audio inputs of the home theater system.
prehaps i am wrong because you say that your yamaha is a home theater* reciever.* is the yahama more than a home theater audio system? What does it recieve?
Idea-- the salesman that you bought it from should be willing to help tell you how to hook it up.
also consider that there are many different ways to hook up vcr's and then dv recorders and dvd recorders and external 2 tera bite hard drives into my tv & dvr . I got that all hooked in & a rats nest of wires. so i can record in hd or sd,on vhs or dvd or dvr
point is that you cant hurt anything by plugging the wrong plug into the wrong jack, as long as the same type of plug goes into the same type of jack.
If its right,it works, if its wrong, it wont work until you plug it into the proper jack.
im sorry ,im 65 am not into knowing all the latest and greatest cutting edge tech ,but i am begining to catch up on my hobby, movie recording tech.
Oct 08, 2013 | AT&T UVerse
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
How do i hook it up to a lcd tv with one digital output?
All of your vidoe components should run directly to TV via HDMI, component, etc., as input. Anything you hook to Tv can be watched using TV's menu, ie: TV, DVR< etc., of course, if you use component cables, you have to provide audio with other means. All you have to do then, is, run your digital optical out from TV to reciever. Use your TV menu to watch and you will only use the one input to reciever. Make sure you go through the recievers menu to make sure you have chosen the proper channel for listening, Vid2, Aux, etc.
Jun 18, 2011 | Sony STR-D665 Receiver
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
I have a yamaha receiver with HDMI outputs for direct tv, and a DVD player. How do I hook up the direct tv, HD DVD, and yamaha receiver? Where do the inputs go?
Does the Yamaha have HDMI inputs? Usually you would connect the directv and dvd player via individual HDMI cables to the Yamaha (input)and then the Yamaha (output) to your TV also via HDMI.
Dec 21, 2009 | Yamaha HTR-5640 Receiver
What is the optimal cable type to connect the Samsung UN55B8500 to a DirecTV HD tuner? Are there specific TV settings to use for this cable type
The best cable hook up to use is the just the one HDMI cable. Just hook it up from box to TV and change the input selection on your TV to HDMI. Then on the Directv Box, change the resolution to 1080 for the best image.
Nov 09, 2009 | Samsung UN55B8000 55 in. LCD HDTV
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
No video
I am not sure if you have gone into the Receivers Menu or not? If you have NOT! Then please try this: Go into the Receivers Menu (If you do not see the MENU on the TV you can hook up a Composite (Yellow) Cable from the Receivers Monitor Out (Yellow) and select the Input on the TV that you plug into) Look in the Menu for Inputs or In/Out Config. or Video Setup. Look for the Input that you are using for that Device. Change the Video setting to HDMI. I also recommend doing this for you Audio as well. Find the Audio Inputs and MATCH each Input to there DEVICE and CABLE (Connection) Being used. Also check in the Receiver Menu for UPSCALE or UPSCALER. Turn this on or off to see if your TV is Compatible! Hope This Helps! P.S. Check the Manual for Upscaling Capabilities NOT all Receivers upscale and route the SAME!
Jan 12, 2008 | Yamaha RX-V861 Receiver
Sony STR-DA5300ES 7.1 Channels Receiver Logo
71 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
