Question about Canon PowerShot SD1000 Digital Camera
What does it mean when it says card locked and how to remove it
  • Canon Master
  • 4,738 Answers
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional troubleshooting tips for this problem.
Posted on May 03, 2010
Card Locked. How to unlock
Do you mean the SD card is locked to "read only" and will not allow the formatting or saving of photos to it? If so, remove the card and you should see a switch on it that slides to lock and unlock it.
Oct 13, 2015 | Cameras
WHAT DOES "WRITE PROTECT" MEANS AND HOW TO REMOVE
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 05, 2012 | GE X5 Digital Camera
Hi I have a Canon 500D and the camera, not the sd card, is is on card lock and I do not know how to remove it. I have looked in menu and gone to 'protect Images' and it says "Card write protected'. ...
Hi Carolyn. There could be several reasons for locked card. 1. pin on side of the SD card must be in UP position, not DOWN2. Reformat your card via computer to FAT323. Card reader inside camera has one "little piece" inside for monitoring if the pin on SD card is pulled down or not. If this "little piece" is bent or broken, your camera could mean that SD card is locked. In this case easiest way is to return camera back to shop. Or if you like, disassembly camera, but you will lost your warranty.
Apr 06, 2011 | Canon Photography
What does it mean when the camera says protected card
It means that the memory card is write-protected.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 05, 2010 | Vivitar ViviCam 8380 Digital Camera 8.0MP...
Can't get by "card locked", what to do ?
hi there remove the card from camera and you will see there is a lock key available in side of the card.
Just unlocked the card and try. If the card is locked then after chance the position you are not going to face those problem. Below sample image of the card. Thanks.
Apr 09, 2010 | Samsung Digimax 370 Digital Camera
How do i format to remove card locked fault
If the card is "locked" this means the slide switch on the side of the card is in the locked position.
Mar 28, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Card locked
Hi...
If your card is locked try to remove the card. See if there is a small button there and slide it to unlock the card. Put your card back to your DG cam.
Good luck.
Regards
PCmania
Sep 01, 2009 | Canon PowerShot A620 Digital Camera
Need help seting up camera
Sd locked means your card is locked so that you cannot delete pictures.remove card & slide locking tab down-the tab is on the edge of the card.hope this helps
Jan 25, 2009 | Moultrie MFH-DGS-100 Digital Camera
Hello
Locked? There is a small tab on the card that slides into the "lock" or "unlock" position.
If you mean "stuck" then you should realize the to remove the card you push it in until it clicks and pops out.
Ken
Jun 26, 2008 | Canon PowerShot A510 Digital Camera
CARD LOCKED
It means the SD memory card has a little switch on the side that is in the "locked" position. Remove card, move switch, re-install, and you should be good to go.
Mar 05, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD1000 Digital Camera Logo
577 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
