Question about Whirlpool Dishwashers
Can you adjust the rotating spray arm? - Whirlpool Dishwashers
    President:
  • 949 Answers
The spray arms are fixed and not adjustable. What kind of problem are you having with them?
Posted on May 03, 2010
Why doesn't upper spray arm function properly?
A couple of scenarios could cause this problem but the simplest might be the way the dishwasher is loaded. The upper spray arm rotates when water is pumped through the vertical supply tube and into the arm. Make sure that you are not loading the lower rack with items that interfere with the rotation of the upper arm rotor. It might also be a good idea to verify that the feed tube that goes to the spray arm is securely connected to the vertical supply tube.
Dec 02, 2015 | Kenmore Dishwashers
Why are the items on bottom rack not being cleaned properly
If is clean dishes in the upper basket, I conclude that the pump produces enough pressure what means that the lower spray arm for some reason does not rotate and because that washing result is bad. Before washing I would check the lower spray arm rotates freely and after that open the door during washing and check if the lower spray arm rotates. Sometimes, the holes in the spray arm clog and disable turning which leads to poor washing results in the lower basket.
Dado
Aug 17, 2014 | Indesit Dishwashers
Indesit di620 dishwasher not spraying water from arms
Hi, you may want to try looking at all the holes in the spray arms. If you see anything blocking a hole, use the tweezers and remove the stuff.
Remove the bottom spray arm and check for items in the water delivery hole.Check the lower spray tower that is connected to the bottom rack. Make sure all rotating parts rotate properly. Look underneath to make sure nothing is stuck in the tower. Remove any stuff stuck that is preventing rotation or clogging the tower.
Jun 26, 2011 | Dishwashers
Both spray arms of my DU943PWKQ0 do not turn or spray. The motor is moving and the it drains without problem. During the wash and rinse cycle I can hear the sound of water, however it doesn't clean at...
Try rotating the spray arms by hand. It should rotate freely. If possible clean the arm rotating place by removing them.
Arms rotate by by pump pressure only. finally check the water pump also.
May 18, 2010 | Whirlpool DU943PWK - Multiple Color...
Upper basket spray does not rotate
check the wash water conduit located on the back wall of the wash cavity from the base up to the center arm if so equipped,then up to the top arm, otherwise the arm itself could be plugged or the spray arm hub could be bad check and make sure arm rotates easily,then remove and make sure there isnt food matter plugging the spray arm holes
Mar 13, 2010 | Dishwashers
Top spray arm does not rotate, is mechanically
try checking the water holes in the arm, as when they spray out the arm turns. If they are blocked in any way it does not turn, try using a needle to check they are clear.
Aug 07, 2009 | Electrolux Kenmore 24 in. Built-In...
Spray Arms won't rotate
good day,
hope this link below will solve your problem.
kitchen appliances
Jul 16, 2009 | KitchenAid Architect? II U SERIES KUDS03ST...
Upper basket spray arm
Have you checked that the cover for the water inlet at the top where it connects to the spray arm is attached? It could have worked loose. Just re-attach and your spray arm should "miraculously" start rotating again!!
Aug 21, 2008 | AEG 24 in. Favorit 40630 Free-Standing...
Lower spray arm not rotating
rotation is only by water coming out of angled jets at end of spray arm. probable that these are blocked. take spray arms out and run water thro centre hole and remove whatever is blocking the jets - usually rice or sweet corn
Aug 05, 2008 | Dishwashers
My Bosch dishwasher model #SHU43C05UC/14 drains well and has enough water(I replaced the inlet water valve already),but not washing the dishes clean especially the top rack.What could be wrong?
open machine when running and check both spray arms rotating - you will get a bit of water out. if spray arms not rotating, usual cause is debris in the arms. the spray arms only rotate by water jetting from angled jets at the end of the arms. take them out and make sure all debris removed
Jul 14, 2008 | Dishwashers
Dishwashers Logo
41 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
