Question about Hampton Bay 52 In. Indoor/Outdoor Tahiti Breeze Ceiling Fan
Chain switch broke
No matter I pulled the chain down, it stays in off position.
  • AsshoIe May 03, 2010
    I found out that the wire broke from the motor. I fixed it and it started working. I thought it was the chain because when I try to turn from low to high, the wire broke.
  • 10,319 Answers
The light fixture then the fans lower housing needs to be removed to gain access to the pull chain switch
Posted on May 03, 2010
The part that is attached to the pull chain inside the fan casing broke
You have to buy a new light pull chain switch. Will either have 2 or 3 wires depending on the type of light you have.
Dec 02, 2013 | Heritage Dryers
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
Hi: I have an bathroom heater fan, Thermosafe model:3208,(new Zealand) one day i found out that i could not turn it on, it even not make the "clip" sound (this heater wasn't designed...
From your description, it sounds like the pull chain ON/OFF switch is broken.Admittedly, this is the first time I have ever heard of a pull chain switch being on an electric heater, But, I guess it is in the ceiling and not wired to a wall switch, it's the only way to turn it ON or OFF. I wouldn't think that replacing the pull chain switch would be that difficult or expensive to replace. Most home centers and hardware stores sell this type of switch for use in ceiling fans, The key would be removing the faulty switch and taking it with you to buy a new one. You want to be sure that the new switch matches the amperage and polarity of the old switch.
As far as the unit only being a year old and the switch failing so quickly ... it's in a warm moist environment 24 hours a day. It doesn't surprise me that the switch broke. You might want to consider replacing the pull chain switch with a hard wired wall switch. Certainly, it would cost more than replacing the pull chain switch, but you'd never have that problem again.
I hope this helped you, Mary. Please let me know.
Jul 14, 2011 | Heating & Cooling
How do you open a wu pin switch. the chain broke & went inside switch
My chain was broken about 1.5 - 2 centimeters inside the wu pin. I took a chain connector (with some chain hanging off one end) and fed it into the hole, trying to connect it to the broken chain. After a couple of tries I managed to get the end of the broken chain inside the wu pin to connect to the chain connector by gently pulling down once it was somewhat inside the chain connector. I hope this works for you. I was so glad I didn't have to resort to cutting any wire or making a trip to a home improvement store!
Jun 13, 2011 | Westinghouse Electric Westinghouse...
PULL CHAIN FOR LIGHT BROKE AND IS INSIDE THE UNIT. HOW DO I GET THE LIGHT UNIT OFF TO GET TO THE PULL CHAIN UNIT.
"PULL CHAIN FOR LIGHT BROKE AND IS INSIDE THE UNIT. HOW DO I GET THE LIGHT UNIT OFF TO GET TO THE PULL CHAIN UNIT."
My oh my!
I don't know of any shortcuts, and the working position does not make the operation a pleasurable one. Not in Summertime!
The time I had to repair that, I needed to pull the whole fan down. Once the whole fan was down, the rest was easy!
It's easier that it appears, but mark all the wires connected in the box.
There is USUALLY a steel cable attached to the fan assembly and the box, to prevent the thing accidentally falling on someone's head.
If you don't have a helper, taking the blades off may be a good idea, but don't take my word for that. Putting them back on was no picnic.
FYI. If you don't have any bead-chain handy, a suitable lenght of sash cord is probably the best replacement.
May 15, 2011 | Hunter (25417) Ceiling Fan
Ceiling fan stuck on low
in order for the remote control to work properly the fan has to be on its highest speed using the pull chain ... after setting the pull chain in the proper position you can tie up the chain or remove it to prevent others from changing the setting .. the remote will control the speed from then on ..
Jun 07, 2010 | Hampton Bay 24002 Ceiling Fan
Can't Find Correct Pull Chain Switch I have a new bathroom wall sconce that has a two lights - a regular bulb and an LED night light. The pull chain switch for it broke and no one at Lowes or Home Depot...
It's called a "momentary switch, normally closed". This is sometimes abbreviated Mom Switch, NC. But I have never seen one with a pull chain before. Maybe you can find one with a toggle that you can attach a chain to.
Good luck.
May 06, 2010 | Electrical Supplies
The pulley chain broke on the light on my ceiling fan and there is no slack to turn the light on or off. Can you please tell me how to fix or replace pulley?
To replace chain switch with a new one (available at a hardware store), first turn off power to the fan. Unscrew the nut on the bottom of the fan which holds the coverplate in place. Find two wires going to the switch, pull them out of the enclosure, take the wire nuts off. Now you can take the old switch out by unscrewing the locking nuts that hold it in place. Put the new switch in by reversing the instructions for removal.
Good Luck.
Jan 20, 2010 | Solar 2-wire Pull Chain Light Switch For...
Hampton Bay 52 In. Indoor/Outdoor Tahiti Breeze Ceiling Fan Logo
245 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
