Question about Dryers
Take a long time to dry - Dryers
  • Dryers Master
  • 43,501 Answers
If you have a gas dryertake a long time to dry - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
Dryer Maintenance
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Posted on May 03, 2010
LG front load dryer jumps from 40 min to 19 min to 5 min in short time. Any suggestions?
Dryers can base their drying time two different ways. If you are using the "dryness" settings, when you first start the cycle, the timer will show a specific time. If the contents dry fairly fast, the moisture sensors in the dryer will reduce the remaining drying time. This may be what is causing your changes. If you want a specific time on the dryer, or the dryness settings aren't getting the clothes as dry as you'd like, opt for a "timed" dryer setting, where you choose the drying time. This bypasses the sensors.
Aug 02, 2016 | LG Washing Machines
My kenmore elite #110.73012181 electric dryer with autonsense feature no longer sensing, keeps on drying for hours after clothes dry when on less dry mode or normal dry mode
The drying circuit has to have a sensor to control heat and the timer controls time (on timed drying). Often sensors fail "open" and dryers stop drying. This sensor or the circuit seems to have failed closed (runs all the time). I suspect the sensor has failed in the drying control.
Jan 02, 2014 | Kenmore Dryers
Kitchenaid superba electric dryer doesn't dry on timed dry
Sounds like a controller problem. May be unable to start a normal dry cycle
Sep 11, 2012 | KitchenAid Dryers
Whirlpool Dryer GEW9200LW1 skip digits when set to dry
If the clothing comes out dry within a normal time,usually 40 minutes or less. Whats happening is the computer is recatulacting the time remaining to dry a load of clothes as it senses they may still not completly dry or even will drop off some time if clotes are dry before time computer calculated at start of cycle.
Gene
Aug 16, 2011 | Whirlpool GEW9200L Electric Dryer
Dryer will not shut off in any 'auto' mode. Time display ticks down, then jumps up again and keeps running. Dryer does works properly when 'timed dry' is selected. Checked and cleaned exhaust vent. ...
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
Jul 14, 2010 | Samsung DV337 Electric Dryer
AUTO CYCLE TAKES A VERY LONG TIME, HEAT IS OK, GAS DRYER
First thing I would check is the vent. If you have good heat but it is still taking too long, usually it is caused by a vent that is either too long , kinked or clogged. if the dryer is auto dry and not electronic dry then you will need to gauge weather the load needs more or less dry. If it is just taking a long time for the clothes to dry, more than likely the vent. If the clothes are dry before it is done running then it is more than likely a setting issue. Way out of the box .... are your clothes spinning out dry enough in your washer? do they dry in the normal time on timed dry?
Dec 18, 2009 | Dryers
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
What is the best setting to dry jeans on a kenmore 9000 electric
Use Auto Dry for most things and vary the "dryness" level to more or less depending on the thickness of the material you are drying. Auto is most efficient and will adjust itself for finish time.
Auto dry and select "more dry" before hitting start, for jeans or towels.
Aug 28, 2009 | Kenmore Dryers
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
Dryers Logo
37 people viewed this question
Top Dryers Experts
