Question about Prime 40 Watt 2 Channel Lead Electric Guitar Amp Car Audio Amplifier
Amplifier sound difficulties
My amp is only giving a extreme low sound. You can barely hear it even when the guitar volume and amp volume are all the way up, at overload/overdrive mode! I tried a new amp chord but no use, what is wrong?
When I turn on my marshall amplifier its makes this unusual, anoying sound. it sounds like a small motor or a fan going. the sound of the amp is good but its just makes this motor sound when I switch it on. can you help me find the problem.
Posted on Jun 04, 2008
SOURCE:
Very Low Sound
It sounds the the speaker has damaged. Check it first. If it is found OK, check and replace the audio output card. It is faulty. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
May 08, 2013 | Viore 32" LED LCD HDTV
Extreme differences on overdrive channel
Please, take it to a tech in your area, or look for a good one to ship it to. An 2007 amp is not old at all.
Jul 24, 2017 | Marshall Mg100dfx 100-Watt Combo Guitar...
Low volume on my marshall
I am very new here and don't know how to answer a question to a specific problem so I will write about the most common problems that I have had over the decades doing guitar amp repairs. If you find that your amp is extremely low in volume and then suddenly comes back to normal- check out the effects return [or power amp in] jack. Especially in Marshall amps-these corrode and your signal dies. If there is loud noise such as hissing and crackling with no guitar patch cord in the input jack- the input jack is likely at fault. They normally have switching contacts that ground part of the input circuit when the 1/4 inch male plug is disconnected. When this in is corroded or too weak to make normal contact, you can get these symptoms. If your amp is a solid state Marshall or Fender and there is a random buzzing sound with no guitar signal connected- hit the side of the amp and listen for the buzz to go away or become louder-if it does, this usually means that the connections are loose at the two large filter capacitors. In one or more Marshall amps, they use a filter circuit in the low voltage power supple for the preamp tubes. If you encounter a dead Marshall[the model escapes me now] remove the circuit board and resolder the four connections at the bottom of the bridge rectifier. If you have any other amplifier repair questions you can email me direct at [email protected]
Nov 14, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
I run a pod HD 500 into the amp and It breaks up, like there is a blown speaker sometimes.
The Marshall is a super clean acoustic amp.
The POD is overloading the amp.
Try the electric guitar input and keep the gain on the amp down, keep the EQ level and use the POD and the end volume to adjust the final volume.
The normal inputs is for a low output acoustic pickup - the POD is a high output electronic source.
Start with the Marshall gains low and get the clean sound good, then work on the gritty sound.
The amp is voiced for a sweet clean sound - if you want grit'n'ball change to a 50w Marshall valve head and a 4 X 12 cabinet.
Horses for courses
Mar 07, 2011 | Marshall Amplification Marshall AS100D 2x8...
When I turn the volume up past 3 it starts this
I suspect you are going into protect mode which backs the gain way off to prevent over driving.
You MAY be trying to get too much volume out of it. Remember that the value of "3" on the volume means ALMOST nothing as you may have a hotter guitar. Some guitars with internal preamps EASILY overdrive the amps at low settings. Do not use excessive gain at the input.
If the amp is real low volume way below what is needed to play, then there may be a problem with the protection/compressor circuit.
Suggestion: Take your guitar to a music store and compare action on an IDENTICAL amp.
Feb 01, 2010 | Music
When I turn the volume past 12 o clock on my PX320 when playing hard the sound clips out. Drops out completely. Any solution to this?
The numerical settingor position of the volume has very little meaning.
If you are clipping, you are overdriving the unit and the unit protects itself.
OFTEN WITH guitars that have preamplifiers built in, one can overdrive the bass amp very easily, even at low settings of the volume control..
Do not continue to overdrive the unit as it is hard on the speakers... without the clipper, you would likely have blown the speaker(s).
IF YOU NEED it louder, then buy a larger amp and speaker setup.
Jan 07, 2010 | Casio Music
Can barely hear sound even though volume is max
thebuzzer of your phone is defected, replace itand replace also the earpiece
Apr 09, 2009 | Samsung Eternity Cell Phone
Amp or guitar??
I can say with a fair amount of certanty that this is the control knob on your guitar, these are fairly cheap and if you have any mechanical ability you can replace it yourself, there will be some soldering involved so if you can't do that I would take it to your local music store and most have some sort of repair department, this shouldn't be a big bill to get fixed.
Feb 11, 2009 | Jackson Dk2m Dinky Electric Guitar
Prime 40 Watt 2 Channel Lead Electric Guitar Amp Car Audio Amplifier Logo
199 people viewed this question
Top Prime Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Prime Audio Player and Recorder Expert? Answer questions, earn points and help others
