Question about Garden
My John Deere LA115 will start and run, sounds fine with clutch in. Will not move forward or reverse. Without clutch in, makes a very strange sound, almost like mower blades are engaging. Noise stops as soon as clutch is pushed in. Mower blades are NOT engaged and deck is up as high as it can go. Do you know what this problem might be and how much it might be to fix?
  • 100 Answers
Sounds like sunwheels blown in gearbox...
Posted on Aug 13, 2010
2 Suggested Answers
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
I purchased a K46 transmission to put in my John Deere LA115. Once installed it worked but pressing revese makes it go forward at slow speed and pressing forward it goes quick at varied speeds.
Try removing the lever on the shaft and turning it 180 degrees, or connecting above or below the pivot point.. This should reverse the operation of the linkage.It will be pushing the opposite way then.
Oct 17, 2016 | John Deere L100 Series
Where can i find a John Deere la115 wiring harness diagram?
The John Deere site has the wiring harness diagram on the LA115 parts diagram in the Electrical section (section 40, page 19). Start here: https://www.deere.com/en_US/parts/parts.page and select the Parts Catalog. http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt is where I ended up. The carburetor is in section 30 (Fuel and Air), page 10.
I hope this helps.
Aug 03, 2015 | John Deere Garden
My john Deere 100 series .... Gear stuck in reverse.... And will not start because it is stuck in reverse!
sit on the mower and push the clutch in
start moving the mower by rocking it forward and backward while trying to put it in neutral,don't worry about your neighbors thinking their is something wrong with you while you are doing this.
Oct 10, 2014 | John Deere Garden
John deere stx46 won't move in forward or reverse
There is a handle on the rear of mower make sure it is not in the free wheel position. If so push it in and it should move. If not seek out an authorized dealer to test your tranny. Also check that your belt didn\'t break
Aug 03, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
How to fix Stuck in reverse Clutch is Fine.?
Have you tried checking the linkage to the hydrostat/transmission? Are you getting full movement of the lever? If not, it might have just come loose and shifted so you only have reverse. If you have full movement of the lever and the hydrostat has the proper amount of fluid it could be fried. It's hard to tell without diagnosing the linkage. I'd suggest blocking the rear wheels off the ground so you don't run over yourself before you go messing with the linkage.
May 14, 2014 | John Deere 22HP VTwin Hydrostatic 42"...
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
May 26, 2009 | Garden
Garden Logo
682 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
