Question about Cycling
Slipping gears As I pedal, the pedals slip as I'm pedaling like it's not staying in gear and it seems like the distance of the jump is about 4 to 6 inches in all gears. Thank you
    Brigadier General:
  • 8,546 Answers
Your chain and drivetrain is probably worn out.
Read this...
http://www.sheldonbrown.com/chains.html
Posted on May 03, 2010
Ford everest 2011 3 litre4x4 dual clutch slipping in top gears clutch has only done 40000 long distance kilometers. Help
if hydraulics clutch system , replace the master cylinder ( blockage in compensating port or incorrect clutch pedal adjustment under dash
if cable clutch replace the cable or again adjust the clutch pedal for free play
Jun 10, 2016 | Ford Cars & Trucks
I just put a new slave cylinder and clutch master cylinder on a 2003 Honda accord 3.0 V6 six speed and you can shift the gears without the clutch pedal pushed in or the car started
that is normal if the gear synchro dogs ( teeth) are in line in the box
problems concerning a clutch are
slashing gears when trying to engage first or reverse with the pedal to the floor ---needs bleeding
slipping when the clutch pedal is released--- slipping clutch from the pressure not being released ---problem in master cylinder
reverse gear is the only gear not synchronised so even with the clutch depressed it is possible sometimes that it will not go into gear unless you let the clutch up to move the gears in the box then attempt to re-engage reverse
May 04, 2016 | Honda Cars & Trucks
What allows clutch to slip so much to not move car.
-Possibly time to replace new clutch.
Good luck
mai
Nov 10, 2014 | 1990 Toyota Camry
The clutch pedal sticks down when trying to engage
YOU DO NEED A NEW DISC AND MOST LIKELY A MASTER AND SLAVE HYDRAULIC CLUTCH CYLINDERS, THE STICKING MAY BE DUE TO OVER TRAVEL DUE TO THE WORN OUT DISK.
May 11, 2010 | 1998 Ford Ranger SuperCab
I have a 89 toyota pickup 4 speed. When I'm stopped at a stop light, and let out on the clutch it seems like it has lost pressure. When I'm shifting down the road it shifts fine. I checked the fluid and it...
this sounds like the clutch slave is goin out, this unit is on the outside of the transmission. Possibly losing pressure!! Your transmission does not use transmission fluid, but instead gear oil. Have the following checked:
1. Clutch Slave (possibly worn)-this will cause soft or hard clutch pedal feel, slipping clutch, unintended clutch release, hard gear engagement, no/insufficient clutch movement.
*2. Clutch pedal Mounting Plate (possibly cracked)-this will cause improper gear engagement, hard gear engagement, soft pedal feel, insufficient clutch movement.
*this plate is located above the clutch pedal itself, apply pressure on the pedal with one hand while inspecting the plate for fatigue cracks(use a bright flashlight). This is very common on these models. This problem will eventually get worst and most mechanics never figure this out.
more questions email me at gimconsulting@ymail.com!!
Mar 15, 2010 | 1989 Toyota Pickup SR5
4 speed automatic slips sometimes
Might be fluid level, make sure it is full but do not over fill!
Feb 12, 2010 | 1997 Pontiac Sunfire
When pedaling the pedal slips when under pressure as if it has worn teeth and the chain is jumping i have the manual but is not clear 735ekg bike
If you have a bicycle with a deraleur system (chain with a lot of different-sized sprockets in the rear), is is possibly because the sprockets are worn combined with a slightly stretched (worn) chain. The best solution is to replace the offending sprockets (they are always the smaller ones) and the chain. You should be on your way. (Before doing ANY of that, however, MAKE SURE that your gears are adjusted properly. A deraleur that is trying to stay between gears will cause just this same symptom.)
Jan 04, 2010 | Cycling
1998/99 Dodge Dakota clutch and manual transmission problems
clutch needing replaced, very common on all manuals
pedal travel adjustment,yes
gear shift adjustment,no
May 12, 2009 | 1998 Dodge Dakota
Cycling Logo
98 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
