Question about Carrier Heating & Cooling
Home air cond carrier A135H auto light flashes
Air cond works for 2 mins aproxx then shuts don and auto light flashes, switch of powerrestarrts then does same thing
Sorry don't have a solution for your problem, but I've got one that you may be able to help me with My Remote control, for which I have no user manual, seems to be locked and the buttons won't do anything. I have noticed a key symbol in the bottom right corner and cas only assume it is locked. Anyone know how I can unlock it? Cheers.
Posted on May 13, 2010
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
No air conditioning, flashing climate light
You should make sure you have proper charge for sure.has your battery gone dead lately? I know on some of them digital climate controls will act exactly like this and have to be reset or go through a setup sequence.
Aug 13, 2009 | 1994 Buick Park Avenue
Air cond dash light works, compressor doesn't go on.
AC's have a low freon switch that shuts off the system to protect the compressor in the advent that you have a freon leak have the system checked for a leak
May 28, 2009 | 1996 Toyota Camry
Carrier split 42G250HF-1(indoor unit
I'm not sure exactly what unit you have and what controls you have installed on the unit. But....there usually is a flash code schematic on the unit. Usually on the inside of the blower compartment cover. This should tell you what is wrong with the unit. It could have a low voltage short somewhere and is loosing the call for cool. So the answer can be a possible yes to your question but without knowing the flash code, it's hard to tell from my point of view. You might end up calling a service professional out to check it.
Mar 30, 2009 | Carrier 38CKC042 Air Conditioner
Air cond drain line
did you check that it is level
Dec 13, 2008 | Carrier 38CKC042 Air Conditioner
Air cond will run for 1-1.5 min then stop , will restart after about 2-2.5 min
you have un under charged unit, under charged of freon. add some freon and check for leak of freon.
Jan 19, 2008 | Heating & Cooling
Heating & Cooling Logo
243 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
