Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Bottom draw want wash this machine has been in storage
When starting bottom draw up / F2 is displayed
can you send me an email to fix the problem or post
Many thanks . Ian
  • Fisher and P... Master
  • 3,247 Answers
F2 indicates motor problem.
I hope you have the user manual.
If not get it from
http://dl.owneriq.net/9/95870094-43e8-493a-96bc-7f786df76d53.pdf
Go to page 21 (cleaning filter plate).
There must be something (a seed or piece of bone) stuck in the rotor chamber. Take the rotor out (impeller) and clean the chamber. Also under there is a small channel between the drain sump and the rotor chamber. Use a stiff thin wire and clean it.
Hopefully the rotor is intact. Replace everything and you should be all right.
Post me a message if the rotor assembly appears cracked. Then you need a new one.
Posted on May 07, 2010
On the 2nd draw will start washing but not even a minute flashes the F2 error and stop washing, what this means?
Hi Francesca, The link below is a short youtube video on how to simply fix f2 on your fisher and paykel dishwasher.......CHEERS..
https://www.youtube.com/watch?v=qP_X9iG0f-g
Mar 29, 2016 | Fisher and Paykel Dishwashers
Not spinning displays e03
hi i have a candy washing machine and it wont turn on with the mains i have tried everthing and it wont come on at all anyone to help me please email me at paul.barnett2@live.co.uk thanks
Dec 03, 2013 | Candy CNW136 Front Load Washer/Dryer
Ok so my netbook goes to a blue screen where it says " press f2 to run setup, press TAB to display BIOS POST message" and stays there. if i push f2 then it goes to a black screen where at the...
Probably the hard drive is dead. Did you drop it recently? Anyway, it could be just the connector, if your good with hardware you could open it and check. I would suggest you to use the warranty though.
Mar 03, 2011 | ASUS Eee PC 1000HE Netbook
Washing machine is sending the F2 message. F2 says the drain in blocked or in someway impaired. After cleaning etc. it still says the same thing
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
* Check the drain hose and make sure it is not plugged or kinked
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Aug 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water from bottom draw
To put machine into test mode: Press and hold keylock, then press and hold start button. Hold both in until machine beeps (if you have display, it will show all symbols). Press power button- display should now show HO. Press start button until LD shows in display- this tests lid motors. Activate lid motors by pressing keylock button- if you open drawer about 3 inches, you should see lid come down. Pressing keylock again will raise lid. Raise and lower lid several times by pressing keylock button to ensure lid is working properly- if not, lid motors need replacing. Good luck!!
Mar 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Washing machine will not spin
post your email i will send you the manual on your unit
Dec 10, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
108 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
