Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool WTW5520SQ0, when draining the water is coming out at such a fast rate it's backing out of pipe and on the floor.
  • Whirlpool Master
  • 43,501 Answers
For many of the new washers you need to have a 2" standpipe and trap... the older 1-1/2" standpipes and traps will not handle the higher volume of the new pumps...
heatman101
Posted on May 03, 2010
My Whirlpool 21. cu. ft top freezer drips water into the refrigerator.
Whirlpool refrigerator and freezer problem. a cup was place in the refrigerator to catch the percipitation coming from an inlet from the freezer. Which they are two inlets located in the center back of the refrigerator from the ceiling adjacent to the floor of the top freezer. the Freezer back t-shape vent goes down to these inlets where the percipitation is coming from. What is this the damper
Mar 15, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The water fills and drain from the bottom of the washing machine. Have checked all the pipes no problem. Please advice
front load or top ? drain hose must be elevated to 36 '' 34 min. if hose on floor it will not work .. needs stand pipe . if its leaking inside you may have a hose off . reinstall and wala it works .. mm hope some of ans work for you ..
Dec 03, 2009 | Ovens
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
My GWL 15 pumps so hard water comes out of the
A washer cannot pump the water out too fast, regardless of what you have done or have been told, the problem is too do do with the drain outlet, I suggest you completely take apart the stand pipe and any other pipes connected, and thouroughly clean them .
Please rate my solution.
Thanks.
Jun 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
NOT DRAINING AND WATER ON FLOOR
hi ya,there is a blockage in your waste pipe take it off and clean it out i had the same prob about 2 months ago
Feb 05, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Refridgerator
Unless your fridge has a water supply connected to i.e for an ice maker,t about the only place the water could be coming from the condensate waste pipe.
Inside most fridges near the evaporator (the cold part) is a drain hole so that any condensate can drain out. This flows thru a tube to the back of the fridge. Normally this tube will feed into a tray and will evaporate away naturally.
You could have a look at the back of the fridge to see if this is happening.
Pease remember to rate this solution.
Dec 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire dishwasher KUDKO31TBT#
you can not take the drain hose straight down thro the floor or the water will drain out as fast as it comes in. you can drain into a spigot on the sink trap or into a vertical pipe connected into your drains via a water barrier
Sep 30, 2008 | Dishwashers
Rinse pipe overflow
Depending on how your drain system is plumbed where you live.. many homes use a 'trap' .. meaning a place where water remains to keep sewer gas from getting back into your home.. If your house is set up with this ( and it may be on the wall or in the floor).. you may have a blockage there that won't allow water to drain fast enough and the pipe fills up and leaks onto your floor.. Hope this helps you...
Sep 24, 2008 | Washing Machines
Water won't drain thru
you need to clean the drain pipe, maybe draino or call a plumber to snake it out.
Aug 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Can't use new washer
youll need to fix your plumbing is what it sounds like,lengthen the drian standpipe, not the drain hose.
Apr 06, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
185 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
