Question about Sunbeam Safety Glide 3891 Iron
I ironed about 2 hours last night before bed. Tried to iron some more (about 16 hours later) and it won't power up. No warning at all. What could be the problem? I didn't drop it.
  • Sunbeam Master
  • 43,501 Answers
If you turned off the switch then it is a good bet the problem is in the switch... otherwise it just decided to quite...at any rate it will cost more to fix it then a new one will cost you...
heatman101
Posted on May 03, 2010
Is my steam iron broke?
Get a new one. If it drew enough power to trip off your electricity then there is a problem that is not worth taking a chance on.
May 07, 2017 | Irons
My iron's MODEL: 14977Z The iron's red light is on but won't heat to iron. was working a couple of hours ago
This is typical of a iron, it is cheaper to replace than to repair. The heating element is broken.
Jun 02, 2011 | Hamilton Beach 14977 Iron with Auto...
Boiler on the iron was empty,used by someone that didn't know this type iron.Turned iron on and later heard this awful noise and husband tried to release pressure and cap blew off but no water was in...
I do not use this model, but it would appear the iron is not affected, just the boiler - like setting an empty tea pot on a hot burner.
Is there any warning that the tank is empty before turning the iron on?
I would refer to the manual for cleaning before using the iron and would not loan anything more valuable than a cup of sugar to anyone.
Mar 19, 2010 | Rowenta DG5030 Iron
Iron stopped working suddenly
perhaps the thermostat is sticking.as irons are cheap to replace i would try cleaning /soaking the tank to remove lime scale. or strip the iron down checking thermostat and conections.
May 01, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Sunbeam 4267-000 not turning on just blinking red
"FF" or a blinking light will display meaning “Fault Found”. The “fault” is in the amount of power available to the blanket, mattress pad or throw.
There are several causes to this problem:
1. Bedding product is plugged into an extension cord, surge protector, power strip, or not plugged into a direct wall outlet.
2. Bedding product wasn't plugged in properly.
To FIX this problem, do the following to reset your bedding product:
1. Unplug the power cord from the electrical connection.
2. Unplug the cord from the actual bedding product itself.
3. Re-plug the cord into the bedding product. Make sure the connection is secure and complete.
4. Re-insert power cord back into a wall outlet.
If the 4 steps above are not followed in order, the bedding product will not properly reset.
Dec 08, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
New iron, stopped heating and leaked water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 22, 2008 | Black & Decker D2030 Iron
CALCIUM BUILDUP COMING OUT OF THE STEAM HOLES...
Hi, the other two responders were correct, use clear or filtered drinking water only. Also, use your iron until it runs dry and use burst of steam or self cleaning function to clear out the last bits of water, being sure it is empty before putting it away. Several cycles of this using and purging process will clean the iron without chemicals. Standing water that evaporates is just like a tea kettle with water left in it, all the white mineral deposits settle to the bottom, and the water dissolves the mineral salts, and when dissimilar metals are wet (think of a an old flashlight battery and the corrosion that occurs if left in storage.
Dec 04, 2007 | Rowenta DX6700 Iron
Light comes on, but iron will not heat up
Like what was posted before, the cause of the iron lights is on but the heaters are not hot is because either your heater connection is melted or rusted due to water seepage(steam irons). The lights power supply are tapped parallel to the heater supply thus lights is on. Solution is to dismantle the iron to replace the connectors or cables. Though not all iron is easy to dismantle
Nov 13, 2007 | Irons
Sunbeam Safety Glide 3891 Iron Logo
69 people viewed this question
Top Sunbeam Irons Experts
Henry  Thomas
Henry Thomas
Tony
Karl H
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
